transmission seal leaking - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 07-19-2010, 10:54 PM Thread Starter
wheres the fat chicks?
PowerstrokeR00's Avatar
i just put in a BTS valve body,new transmission filter and fluid.i toped the fluid off and now its leaking on the left side of the pan where the the rubber gasket is.i torqued all the pan bolts to 120 in lbs.then after i realized it was leaking i tighend them another 1/4 turn.any ideas,thanks
2000 F-350 SD ccsb=185hp
Matt's Tunes=140hp
6637=20hp
2% window tint=25hp
4in straight pipe=50hp
Custom Fuel system w/ sump=50hp
Foil,AIH,EBPV delete=30hp
Wow...I'm making 500hp
Originally Posted by stroke of luck View Post
i started sharting at an early age...
PowerstrokeR00 is offline
post #2 of 3 (permalink) Old 07-20-2010, 12:47 AM Thread Starter
Re: transmission seal leaking
bump
Matt's Tunes=140hp
6637=20hp
2% window tint=25hp
post #3 of 3 (permalink) Old 07-20-2010, 10:51 AM
riverjet
Check the pan rail and make sure it is not bent anywhere.The pan should seal up easily even with many bolts missing.
2001 f250 xlt reg cab 4x4,7.3 stock injectors,water/meth,ITP rr,walbro,5/8 pu,BD/MANN ccv,DP F5,OILGUARD,stock turbo,WW,ATS,1.0 exh.housing,high flow outlet,MBRP4",Billet 3-disk,built trans,Billsteins,11 ISSPRO PERFORMAX gauges,Scan gauge,08 rear cover,350 blocks,x-springs,AFE stg2/pg7,P265/75r16 NITTO Terragrapplers.
riverjet is offline
