What converter? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 16 (permalink) Old 08-07-2007, 05:00 AM Thread Starter
TRX370r's Avatar
What converter?
What converter are the guys using that don't have a built trans using? Mine has really started to build alot of heat when driving around town and when ever the converter is not locked up. More than it used to anyways, with 100 deg outside with the ac on in town it will creep up to 195-205 deg. If I'm going down the road over 45mph even with 6k in tow if will only see 180 @ best.
Never used to see over 180 unless I was towing even in town.
I think my converter is going south is this a good diagnosis? I want to get a JW trans not just ready for the $ it takes yet. I'm only at 65,500 miles.
Thanks guys, I can from TDS under a different name.
The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government.
Thomas Jefferson
Beans Diesel Performance
TRX370r is offline
post #2 of 16 (permalink) Old 08-07-2007, 05:03 AM
Re: What converter?
I would talk to John, a 6.4 converter should be a good option for you.
Pretty sure you can get the adapter, flexplate, and converter from him.
I'm running an "updated" triple disk 7.3 converter and it's holding good, the 6.4 convs are even tougher.
www.jwtt.com
gregrob is offline
post #3 of 16 (permalink) Old 08-07-2007, 05:04 AM Thread Starter
TRX370r's Avatar
Re: What converter?
Good to know. How do you like the 1.o ex housing?
Thomas Jefferson
TRX370r is offline
post #4 of 16 (permalink) Old 08-07-2007, 05:05 AM Thread Starter
TRX370r's Avatar
Re: What converter?
Does john post here?
Thomas Jefferson
TRX370r is offline
post #5 of 16 (permalink) Old 08-07-2007, 05:06 AM
Re: What converter?
Send a PM to Transman
gregrob is offline
post #6 of 16 (permalink) Old 08-07-2007, 05:07 AM
Re: What converter?
Better than stock, but a little more laggy.
gregrob is offline
post #7 of 16 (permalink) Old 08-07-2007, 05:11 AM Thread Starter
TRX370r's Avatar
Re: What converter?
Lower egt? do you run lower boost #'s?
Thomas Jefferson
TRX370r is offline
post #8 of 16 (permalink) Old 08-07-2007, 05:12 AM Thread Starter
TRX370r's Avatar
Re: What converter?
I'm highjacking my own thread,lol
Thomas Jefferson
TRX370r is offline
post #9 of 16 (permalink) Old 08-07-2007, 05:14 AM
Re: What converter?
Can't say there was a noticeable difference in egt's.
I have done so much stuff since I swapped that I couldn't comment on boost either. I think the smaller housing might make more boost but really overdrive the turbo. The bigger housing is a little more efficient for drive pressure, etc.
I felt like it pulled a little harder on the top end with the larger housing.
The .84 kinda choked out at higher boost levels and the 1.0 seems to keep pulling.
gregrob is offline
post #10 of 16 (permalink) Old 08-07-2007, 03:44 PM
Re: What converter?
My new tow master trans uses a new 6.4 converter.This converter is great
for the guy running 400 hp and less.The 6.4 and 6.0 have the same stall.But
the 6.4 now has harden splines and new design tripledisc clutch. I will be testing this converter in my friends twin turbo 7.3 just to see what it takes to break it! All of my billet converters are still built from new 6.0's. I buy them from ford and send them to TCS for building. Remember the big problem with
this trans is not the converter pursae. The problem is the stock frt pump can not keep the converter full of oil! No matter who's converter if you do not fix
the problem you have not fixed it at all!
Transman
Transman is offline
