Trans temp gauge question - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 07-14-2010, 04:42 AM Thread Starter
edge186's Avatar
Just wondering which would be a more accurate reading - a gauge that reads straight from the tranny or a monitor that reads from the computer? Im tired of my pos Isspro gauge not working and have been thinking about Edge's new Insight CTS. My bro in law has both a CTS and Autometer gauges in his OBS and the CTS reading is slightly lower than the gauge.
2001 F-250 PSD 4x4 Lariat CC SB Auto
Power Hungry Performance
Edge CTS Insight
ATS 4" Straight Pipe
ATS Ported Compressor Housing
AFE Stage II Intake
DI Stainless Up-Pipes
BTS Valve Body
6.0 Billet Converter
6.0 32 Row Trans Cooler
Foil Delete
AIH Delete
CCV Mod
Firestone Ride-Rite airbags
edge186 is offline
post #2 of 7 (permalink) Old 07-15-2010, 12:04 AM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Re: Trans temp gauge question
They are both accurate, but read the temperatures at different places.
Mark Kovalsky is offline
post #3 of 7 (permalink) Old 07-15-2010, 12:05 AM Thread Starter
edge186's Avatar
so if i get a edge monitor that reads off the computer, what temps should i be looking for? what would be considered the safe range?
Edge CTS Insight
AFE Stage II Intake
BTS Valve Body
Foil Delete
AIH Delete
CCV Mod
edge186 is offline
post #4 of 7 (permalink) Old 07-24-2010, 08:20 PM
<-- GO BRONCOS
dblamp's Avatar
From Tank's library:
Anthony
2002 F-350 SRW 4x4 Lariat Crew Cab, Auto, MBRP 4" T409 Turbo back, AFE Stage 2, Isspro gauges (Pyro, Boost, Trans), BTS VB, DP F-5
(No start, Modified Stock, 60T, 80E, 120race)
Democrats are tyrants.
Republicans are cowards.
Jesus Christ is our only hope!
dblamp is offline
post #5 of 7 (permalink) Old 07-24-2010, 09:59 PM
Tank's library is good if you're using 1960's fluids. Those charts are worse than useless for modern transmissions and ATFs.
You can run as high as 220F all day long with NO problems. Your trans and trans fluid life is NOT shortened as shown in those charts. You can run as high as 250F for up to 1/2 hour with no problems.
Mark
The good thing about science is that it's true whether or not you believe in it. ― Neil deGrasse Tyson
post #6 of 7 (permalink) Old 07-24-2010, 11:22 PM Thread Starter
edge186's Avatar
Thanks guys but my question is if a gauge and the computer read two different temps and anything under 220 on the gauge is ok, then what is ok from the computer reading? Am I making any sense? Haha
Edge CTS Insight
AFE Stage II Intake
BTS Valve Body
Foil Delete
AIH Delete
CCV Mod
edge186 is offline
post #7 of 7 (permalink) Old 07-30-2010, 05:36 AM
<-- GO BRONCOS
dblamp's Avatar
I did not know that, thanks for the updated info Mark.
Anthony
dblamp is offline
