6.0 cooler or tru-cool?? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 22 (permalink) Old 07-07-2010, 12:25 AM Thread Starter
Well i'm planning on getting either a tru-cool to add to my stocker or just replacing with a 6.0 cooler which would be better? The money factor isnt a huge deal just wondering which option would be better.
00 Excursion. TS 6 position chip, AEM Intake, 4" Turbo back exhaust, wicked wheel, Transgo tugger, Gauges, 8" BDS Lift w/37x12.50.
JoesEX is offline
post #2 of 22 (permalink) Old 07-07-2010, 12:33 AM
riverjet
Re: 6.0 cooler or tru-cool??
Ifyou had a new BTS or JW I would say get the 6.0cooler. For a stock trans get the tru-cool.More cost effective and lowered my temps 30 deg. 6.0 cooler is to much money and if the stock trans fails I would not re -use the cooler on a new build.
2001 f250 xlt reg cab 4x4,7.3 stock injectors,water/meth,ITP rr,walbro,5/8 pu,BD/MANN ccv,DP F5,OILGUARD,stock turbo,WW,ATS,1.0 exh.housing,high flow outlet,MBRP4",Billet 3-disk,built trans,Billsteins,11 ISSPRO PERFORMAX gauges,Scan gauge,08 rear cover,350 blocks,x-springs,AFE stg2/pg7,P265/75r16 NITTO Terragrapplers.
riverjet is offline
post #3 of 22 (permalink) Old 07-07-2010, 12:48 AM
Caption This
444-4D's Avatar
That's easy, the 6.0 is better.
If only those who knew what they were talking about replied, this thread would still be on page one.
2000 F-250 CC 4x4 PSD Auto
444-4D is offline
post #4 of 22 (permalink) Old 07-07-2010, 01:25 AM
Busted Knuckles
PSDEng's Avatar
Just put the tru-cool on my BTS drove 200 in 90 degree weather at 70 mph and didn't see any temps over 140.
'97 Powerstroke SCLB:
i have a couple friends that went balls deep in wyotech and when they got out they couldn't poor piss out of a boot if you put the directions on the sole
PSDEng is offline
post #5 of 22 (permalink) Old 07-07-2010, 01:32 AM
<----Nice headlights!!!
TylerDurden's Avatar
You can buy an aftermarket cooler that will stomp the balls off a torqshift cooler. They were popular because they were cost effective. They arent anymore, I dont consider this a good mod for the price. 3-400 for a stock transcooler? Thats nuts! Get a Hayden or check anybody that makes torqconvertors cuz they probably make one. Alot cheaper too!
2000 F250 4x4 cc/sb. 6" w/37's and some other stuff.
TylerDurden is offline
post #6 of 22 (permalink) Old 07-07-2010, 01:38 AM
Caption This
444-4D's Avatar
The best aftermarket cooler made is a 4739 Tru Cool. It is about half what the torqueshift cooler is.
444-4D is offline
post #7 of 22 (permalink) Old 07-07-2010, 05:35 AM Thread Starter
ok thanks guys..i'll probably do the tru cool, would synthetic fluids and a mag hytec pan/pml pan help out temps any? Dont really have too much trouble with it getting warm except for when pulling out my buddies pre-runners and was worried bc i'll be buying/towing a boat this summer.
JoesEX is offline
post #8 of 22 (permalink) Old 07-07-2010, 12:36 PM
A Ghost these days...
farm boy's Avatar
I like my cooler from Diesel Site. It was well worth the $120 whatever dollars. I wanted the 6.0 cooler but I didn't want to un ass the money.
And yes, the Mag Hytec pan will help cool things as well. That pan also has something that helps hold the trans filter in place and keeps it from cracking.
2002 F-250 4X4 Flatbed
~Cryo'd Forged Rods ~Comp 910's ~DI Push Rods ~ARP Studs ~IH Up-pipes ~GTP38R/1.15 ~238/80's ~Fuelab ~Built Auto ~Matt's Tunes ~Water Inj. ~Gooseneck Brand Flatbed
Rockin' Out with some help from: Alpine / Rockford Fosgate / Memphis / Infinity
farm boy is offline
post #9 of 22 (permalink) Old 07-07-2010, 05:31 PM
Busted Knuckles
PSDEng's Avatar
Don't ask me why but when I talked to Brian at BTS he asked me if I kept the stock pan on my tranny from him and he for some reason he wasn't a big fan of an aftermarket pan. Just an fyi so you may want to do some more research on that topic.
PSDEng is offline
post #10 of 22 (permalink) Old 07-07-2010, 07:47 PM
Let'er Buck!
Strokersace's Avatar
He's not a fan of the deep pans because they are just that, too deep. Yeah, you get more airflow across them to help cool, but it actually has a negative affect on the fluid inside. See the filter/pickup tube gets the fluid off the bottom of the stock pan. But when you install a deep pan, you're sucking fluid from the upper part of the fluid, not the bottom. Brian's thought is that you're not getting proper fluid flow resulting in greater inefficiencies by having a deep pan and stock filter/pickup.
I got truck stuff...
Strokersace is offline
