E4OD Check Valve - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 06-23-2010, 04:49 PM Thread Starter
USASF Retired
halo's Avatar
E4OD Check Valve
I want to upgrade my cooler lines to 3/8" since my factory lines are 5/16" and I'm installing a 6.0 31 row cooler.
Can I replace the check valve in the side of the transmission where the return line connects with an inline check valve?
Also can I remove the fittings on the radiator where the cooler lines connect to replace them with 3/8" fittings?
Ideally I would like to run 1/2" lines for the whole system but I don't think I can get that big of a fitting (-8AN) into the radiator. If I bypassed the radiator though it would be no problem.
Do I really need to run it through the radiator?
Wow that was long.......................
1996 F-350 Crewcab 4x4 7.3 PSD E4OD
"The pacifists always lose, because the anti-pacifists kill them." - Raymond S. Kraft
"The true soldier fights not because he hates what is in front of him, but
because he loves what is behind him." -G. K. Chesterton
halo is offline
post #2 of 4 (permalink) Old 06-24-2010, 04:08 PM Thread Starter
USASF Retired
halo's Avatar
Re: E4OD Check Valve
Will the cooler bypass from a 4r100 fit on the e4od?
halo is offline
post #3 of 4 (permalink) Old 06-26-2010, 03:01 AM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
The radiator takes a HUGE amount of heat out of the ATF. You can bypass it, but you will lose a lot of cooling capacity, especially at low speeds where the transmission makes a lot of heat.
I don't know. I'm pretty sure the distance between the fittings is identical, but I don't know about the threads.
Mark Kovalsky is online now
post #4 of 4 (permalink) Old 06-26-2010, 04:12 AM Thread Starter
USASF Retired
halo's Avatar
Thanks Mark!
I got the cooler installed today and I am reusing the 5/16" line. I built some nice reducers.
If it works I will keep it the way it is, if not I will attempt to upgrade to larger lines.
halo is offline
