Speedo gears - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 1 (permalink) Old 06-20-2010, 11:03 PM Thread Starter
Speedo gears
The 99+ vans have 4r100's and the vss is a speedo gear in the tail housing, as opposed to the trucks where the vss is in the rear end.
Do the e4od obs trucks have a speedo gear like this? Either 2wd or 4wd? I ask because the vans only had 2 available gear ratios, 3.55 and 4.10. I am looking for a 3.73 speedo gear to test something, and hoping one from an obs truck will work, if they even used speedo gears in the tail housing.
Thanks.
03 E-350 7.3, forged rods, exhaust ported heads, comp 910's, 38R/47, 4.10LS, stealth twin pumps, 300cc hybrids from Swamps, h-11's, racerx trans and TC, Swamps tunes, water...
rpm-inc is offline
