Tran temp sending unit location? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 06-19-2010, 02:14 PM Thread Starter
Hey Guys
Sig truck E4OD has the trans temp sending unit mounted on driver's side about an inch off bottom of pan about mid pan (from the front). The pan is the ford updated pan with drain plug in it.
Anyone know what the temp reading diff would be compare to the access port which is higher up on tranny?
Thanks,
jrc
Tan white tan 97 ECLB, D60 PMF, RSK SD springs front, airs bags rear, 4:10, intake, DP 4 exhaust DIY E-fuel, ZF-5 now
B&W turnover 5th wheel with Anderson hitch.
JCart is offline
post #2 of 2 (permalink) Old 06-19-2010, 02:20 PM
Kip
Kip's Avatar
Re: Tran temp sending unit location?
I was told when I added my aftermarket pan that its was alittle hotter in the pan. If this true or not I don't know but if its not true the pan is a complete waste of money. IMO they are anyways.
2005 Chevy Duramax (thats right I have a chevy and am on PSN. I use to have a PSD and I like this place.
THE SAINTS still suck GO COWBOYS!!!!
Kip is offline
