Slight tranny shudder from a dead stop - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 06-17-2010, 07:56 PM Thread Starter
Airboat nut
It might not be anything ? I hope as I'm hauling a 27' camper this weekend..!
When I'm at a dead stop and have the front wheels turned , I can look back at the rear tire and see and slightly feel a shudder.
Trans is full of fluid and looks good.
No other problem present, no lights , tranny temp in middle of gage range when warmed up.
Its a 06 F250 4x4 BTW , 132,000 miles.
Is that normal ? Should I be concerned with pulling 8000 lbs of travel trailer on Sat ? This is a new truck to me so it may just be me going from a Toyota preruuner to a real truck....
Thanks Gents,
BB
Outstanding.
Brotherbob is offline
post #2 of 7 (permalink) Old 06-17-2010, 08:12 PM
<---- Funny
wriott's Avatar
Re: Slight tranny shudder from a dead stop
does it do it without the front tires turned??
Will
2002 F-350 CC LB 4x4 DRW
3 other PSDs, Low-Pro Freightliner, and 12 other diesel trucks
Random pics
wriott is offline
post #3 of 7 (permalink) Old 06-18-2010, 11:21 AM Thread Starter
Airboat nut
Not that I can tell ....
Outstanding.
post #4 of 7 (permalink) Old 06-18-2010, 12:24 PM
Rock Steady
Truck lifted ?
2000 F-450 Dump NLTD tunes
4duggan is offline
post #5 of 7 (permalink) Old 06-18-2010, 04:14 PM Thread Starter
Airboat nut
Stock truck on stockish AT tires.
Outstanding.
post #6 of 7 (permalink) Old 06-18-2010, 04:32 PM
they call me tater salad
jawsfx4's Avatar
im not sure about the sd but my 05 half ton fx4 had clutches in the rear end for the posi maybe they arent working right and it stays locked and the tires cant turn at different speeds causing the wheels to hop when you turn
08 white cclb 4" straight pipe into 8'mitre cut black stack,dpf delete,egr delete,arp studs,6" fabtech lift,metal mulisha wheels wrapped im 37" toyos,sct running extremex,kenwood double din running two ten inch type r through a m1000,homemade front and rear bumpers, beamers hids
jawsfx4 is offline
post #7 of 7 (permalink) Old 06-21-2010, 02:01 PM Thread Starter
Airboat nut
I guess it was just me....
It pulled that 27' travel trailer just fine no problems , no lights , tranny temp was in the middle the whole time.
It's all good.
BB
Outstanding.
