Trans Cooler for my '97 F-350 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 38 (permalink) Old 06-11-2010, 08:25 PM Thread Starter
V97F350's Avatar
I will be pulling my 36' Tavel Trailer in a couple weeks and I should install and Tanny cooler. What should I get.
$$$ is very limited...
'97 F-350 4x4 Crew Long Box Auto 4.10 6637 Air Filter, 3" Downpipe, Rebuilt E4OD
V97F350 is offline
post #2 of 38 (permalink) Old 06-11-2010, 08:35 PM
Re: Trans Cooler for my '97 F-350
I know diesel site has an awesome trans cooler.
Trans cooler
best would be to install a 6.0 trans cooler
02 f250
countryboyrob is offline
post #3 of 38 (permalink) Old 06-11-2010, 08:52 PM Thread Starter
V97F350's Avatar
This looks to be for a 99-03 - will it work on my '97?
V97F350 is offline
post #4 of 38 (permalink) Old 06-11-2010, 09:12 PM
"If you have any other model of transmission, you will need to check with your repair manual or parts department to see if your transmission is equipped with a bypass valve. If it is, you don't need one. We know that 1994-1996 E4OD transmissions DO NOT have a bypass and will require the unit with the bypass valve. The bypass valve will help these vehicles maintain minimum operating temps of the fluid. "
so basically you would have to get the tru cool 4739 with the bypass valve.
02 f250
post #5 of 38 (permalink) Old 06-11-2010, 10:21 PM
Busted Knuckles
PSDEng's Avatar
they yold me i didnt need one with my bts?????
'97 Powerstroke SCLB:
i have a couple friends that went balls deep in wyotech and when they got out they couldn't poor piss out of a boot if you put the directions on the sole
PSDEng is offline
post #6 of 38 (permalink) Old 06-11-2010, 10:49 PM
It wasn't me
offroadinginaz's Avatar
That is a great tranny cooler. My Mom's 97 was getting really hot towing a 3 horse slatn. I installed that and it never goes over 190.
Newman
A few Fords
Special Thanks to:
offroadinginaz is offline
post #7 of 38 (permalink) Old 06-12-2010, 02:01 AM
I believe your bts comes with either the v10 cooler or 6.0 cooler.
02 f250
post #8 of 38 (permalink) Old 06-12-2010, 02:04 AM
Busted Knuckles
PSDEng's Avatar
Well i was under that impression too then i called matt at beans (i ordered it through them) and they said it didn't so i bought a trucool from dieselsite and they said i didn't need the bypass valve (sorry for the derail OP)
PSDEng is offline
post #9 of 38 (permalink) Old 06-12-2010, 02:28 AM
Since its an e4od I would assume that you would need it. I would ask another obs owner that has a bts just to make sure.
02 f250
post #10 of 38 (permalink) Old 06-12-2010, 01:12 PM
USASF Retired
halo's Avatar
What is the min op temp? I just installed th 6.0 cooler on my 96. Where do I get a bypass valve if I need one?????
1996 F-350 Crewcab 4x4 7.3 PSD E4OD
"The pacifists always lose, because the anti-pacifists kill them." - Raymond S. Kraft
"The true soldier fights not because he hates what is in front of him, but
because he loves what is behind him." -G. K. Chesterton
halo is offline
