95 F350 truck wont go into reverse - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 06-01-2010, 03:44 AM Thread Starter
http://www.midnightmods.com/2009/11/...ifter-kit.html
So everything is going fine. Went to grocery store and manual trans wont go into reverse. I move shifter all the way over to the right and try pulling down and wont even try going into gear.
Get it home and start ripping stuff apart. I notice I dont have a spring were this write-up does. On the 12th pic down I am missing this spring. I pulled inspection cover off the side and send a magnet around and found spring. Reinstalled it and temporarily bolted down shifter and truck WILL go into reverse now.
So my question: from what i understand this spring just returns shifter back to middle position. what is the "reverse lockout" I hear about? was the spring my problem? How does the reverse lockout work?
03 F-350. EGR delete, ARP studs, BPD 7.3 fan clutch, coolant filter, cat delete, AT, 3.73s.
sg465 is offline
post #2 of 3 (permalink) Old 06-01-2010, 09:56 PM Thread Starter
Re: 95 F350 truck wont go into reverse
Update, Got back together. It WILL NOT go into reverse from 5th. If Im in any other gear and try reverse it works. I know 5th and R are on the same shaft so what technically is messed up inside there?
sg465 is offline
post #3 of 3 (permalink) Old 06-02-2010, 05:41 PM
Butt-Head
PHPDiesel's Avatar
Nothing.
That's the way it's supposed to work. See the reply I gave on "the org.".
Cody
PHPDiesel is offline
