Clutch Help - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 06-01-2010, 03:36 AM Thread Starter
Road Hammer
sniper_101's Avatar
Clutch Help
Truck in signature, got it this weekend.
It hesitates/grabs going into all gears (even when clutch to the floor, causes rough up-shifts), engages just past half-way pedal travel. The truck has been sitting since fall last year. Clutch doesn't seem to slip, but haven't towed or really worked it yet. Original clutch I believe.
Any suggestions?
Can the clutch be adjusted at all? Air in the line? Worn clutch?
Thanks guys, search turned up mixed answers.
Edit - There is a little oil on the bottom the bell-housing and around the starter if it matters.
00' F350 XLT - SCSB, 4x4, 6-spd
94' Ranger - 306/5-spd in progress
06' KTM 525 EXC-R - Dual sport & SuperMoto
sniper_101 is offline
post #2 of 6 (permalink) Old 06-01-2010, 03:54 AM
Team Shade-Tree Mechanic
Mini-Stroke...'s Avatar
Send a message via AIM to Mini-Stroke...
Re: Clutch Help
sounds like a possible bent clutch fork
96 PSD 4X4, 33's, intake, 4" straight exhaust, Autometer NV gauges, Edge
, ZF5 tranny, LUK clutch. D60 swap in the works......
87 Diesel ranger 4X4
Mini-Stroke... is offline
post #3 of 6 (permalink) Old 06-03-2010, 10:53 PM
Re: Clutch Help
Bent clutch fork, weak hydraulics or weak pressure plate fingers. Or bad stoopid pushrod bushing.
Get an assistant; slither under, and while an assistant operates the pedal, FULL travel, measure the distance the poking-out end of the fork moves. IIRC, it should be about 7/16"-1/2" (12-13mm). If it's less, then the problem is "upstream"; pedal / pushrod bushings and/or hydraulics. If it's at least that much, then it's a bent fork or the pressure plate just isn't springing with the fork / throwout bearing travel.
madpogue is offline
post #4 of 6 (permalink) Old 06-09-2010, 02:15 AM Thread Starter
Road Hammer
sniper_101's Avatar
Re: Clutch Help
Thanks guys, I'll give it a look-over this week, as taking 5 minutes to get up to speed trying to get it into gears, and do it relatively smoothly get old, fast. I've sat at a green light more than once trying to find 1st (2nd), and often when I do get it into gear you can feel the truck lurch forward, but it does slip into every gear a lot easier if accelerating harder than usual/normal driving.
Any other suggestions? Thanks again guys!
post #5 of 6 (permalink) Old 06-13-2010, 03:18 PM
Edward Scissorhand WanaB
Bushwakd's Avatar
Re: Clutch Help
It is time to investigate what is going on. I had the exact same problem on a 99.5 F450 at work. The clutch disk was cracked and a spring came loose. The Ford clutch disk is famous for cracks and springs coming loose. I used this http://www.dieselsite.com/index.asp?...ROD&ProdID=123 and this http://www.dieselsite.com/index.asp?...ROD&ProdID=588 and http://www.dieselsite.com/index.asp?...ROD&ProdID=124. I also bought a new Slave/Master cylinder and a new clutch pedal assembly. The reason for the new pedal assembly was because there is a small post on the side of the pedal arm that attaches to the push rod and the post gets worn and begins to get a little slop in pedal to push rod travel. The post attaches to the push rod via a plastic retainer bushing that connects the two parts together and when the plastic bushing wears out you get metal to metal and the wear begins. Everything I described has fixed my clutch problem to good as new status. I have the Luk Clutch/Flywheel in three of my work trucks. Time will tell if they hold up to the commercial abuse.
"Real Trucks Don't Have Sparkplugs"
2000 F-250 Lariat, CC, 4x4, LWB,
A few mods to make it better than stock.
250cc hybrids, Stealth stage II HPOP, H-11 Headstuds, Strickly Diesel Reg. Return Fuel, Spearco 6.0 IC, Garrett 38r 1.15 hsg, BTS transmission, Gearhead Tuning
"The Smoke Don't Mean Its Broke"
Bushwakd is offline
post #6 of 6 (permalink) Old 06-17-2010, 02:09 AM
Re: Clutch Help
Any of these things cause a vibration/tap in the floor of truck. I have it when accelerating. If I let out off accelerator it isnt as bad or push in clutch it goes away.
1999.5 FORD F250 SUPERDUTY 4X4 EXT CAB
7.3L POWERSTROKE DIESEL
6 SPEED
SWAMPS STAGE 1 SINGLE SHOT INJECTORS
SWAMPS TUNING
6" AUSSIE STACKS
AFE INTAKE W/ PRO GUARD 7 FILTER
VAN TURBO
4" SUSPENSION LIFT
315/75/16 BUCKSHOT MAXXIS MUDDER TIRES ON STOCK WHEELS (WINTER TIRES)
16X9 MOTO METAL 951 BLACK WHEELS (SUMMER)
COWL HOOD
99STROKINSMOKIN is offline
