Trans Rebuilder telling me soft shifts and flaring are computer related-True??? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 15 (permalink) Old 05-31-2010, 11:59 PM Thread Starter
Diesel Only!
I have a 95 PSD Van and I just had my E4OD rebuilt. The guy who rebuilt it (an ex-ford trans tech now doing independent trans work on the side) said that he wasn't quite happy with it after the rebuild and I'm noticing the same problems he noted... it's certainly not driving like it should drive when it came off the lot.
I'm getting soft/slow/spongy shifts at most types of acceleration (slow and even WOT acceleration). I'm getting flaring RPMs between gears and I'm getting bogging down going into 4th gear.
None of this seems right. The guy who did the rebuild is saying that it's electronics (PCM) causing the problems.
Is this right or is it a cop-out of having to go back in? It seems to me that the valve body would control how firm the shifts are. Doesn't the computer simply tell the trans when to shift or also the firmness of the shift? Is there a modulator on the transmission? If so what controls that?
777funk is offline
post #2 of 15 (permalink) Old 06-01-2010, 01:24 AM
riverjet
Re: Trans Rebuilder telling me soft shifts and flaring are computer related-True???
Get him to fix it.Yes a computer can cause problems,but most not likely.I made a mistake of listening to that computer BS!
2001 f250 xlt reg cab 4x4,7.3 stock injectors,water/meth,ITP rr,walbro,5/8 pu,BD/MANN ccv,DP F5,OILGUARD,stock turbo,WW,ATS,1.0 exh.housing,high flow outlet,MBRP4",Billet 3-disk,built trans,Billsteins,11 ISSPRO PERFORMAX gauges,Scan gauge,08 rear cover,350 blocks,x-springs,AFE stg2/pg7,P265/75r16 NITTO Terragrapplers.
riverjet is offline
post #3 of 15 (permalink) Old 06-01-2010, 01:34 AM
Science rulz
Coltaine's Avatar
Send a message via AIM to Coltaine
If it wasn't doing it before the rebuild then it shouldn't just suddenly start doing it after the rebuild..
One of them truckless bastards.
Coltaine is offline
post #4 of 15 (permalink) Old 06-01-2010, 01:41 AM Thread Starter
Diesel Only!
The problem is that I bought the van with no 4th gear so I don't know too much about it's history. It seemed like the flaring shifts are a new thing though. I really don't recall the soft shifts.
It doesn't always flare and it's not a huge flare but the RPMS do increase a bit mid shift.
777funk is offline
post #5 of 15 (permalink) Old 06-01-2010, 01:41 AM
Don't EFN worry about it
Aljay's Avatar
Yes but the VB needs some parts to make the shifts right sometimes springs, valves. Did he put in the good shift solinoid ? Sometimes the linepressure needs to be fiddled with that can be in the tuning.
Tuned by T Wildman
Aljay is offline
post #6 of 15 (permalink) Old 06-01-2010, 03:03 AM Thread Starter
Diesel Only!
He said that he put all new solenoids into the trans.
777funk is offline
post #7 of 15 (permalink) Old 06-01-2010, 03:05 AM
Aljay's Avatar
The orange one is one of the best.
Tuned by T Wildman
Aljay is offline
post #8 of 15 (permalink) Old 06-01-2010, 03:13 AM Thread Starter
Diesel Only!
not sure what the orange one is but I'm guessing the better solenoid? I'm not sure what he used for them.
777funk is offline
post #9 of 15 (permalink) Old 06-01-2010, 03:18 AM
<----Nice headlights!!!
TylerDurden's Avatar
If you paid for a rebuild then you should get a rebuild. If he needed to replace more parts that werent originally quoted you should have gotten a phone call to say "hey its gonna cost a little more". If he cant fix it after another 'tinkering' then ask him if he knows somebody who will. Or ask for the money back/different transmission. Doesnt sound right to me.
2000 F250 4x4 cc/sb. 6" w/37's and some other stuff.
TylerDurden is offline
post #10 of 15 (permalink) Old 06-01-2010, 03:45 AM
riverjet
I was told by my connection at the Ford dealership,the orange is Fords updated-post99 solinoid pack to cure the4r100 3-4 shift flare issues. The casting flows better.Transgo addressed this in their kits by drilling more holes in the casting if you have a older casting.
riverjet is offline
