trans gauge acting up - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 05-31-2010, 02:22 PM Thread Starter
oldbluef250's Avatar
So I noticed recently that my trans gauge will rise and fall about 50 degrees every now and then, especiallly when its just getting warmed up. Also more recently, it will get warm fast. Like around 190*. I know people say this is normal, but a few months ago, it would take over 50 miles before it would even reach 130*, and now it reaches 160* in about 10 miles. Should I change fluid and flush it out? The last fluid change it had was about 60,000 miles ago.
2003 F350 cclb 6.0
oldbluef250 is offline
post #2 of 3 (permalink) Old 06-01-2010, 09:04 PM Thread Starter
Re: trans gauge acting up
bump anyone?
2003 F350 cclb 6.0
post #3 of 3 (permalink) Old 06-01-2010, 09:30 PM
riverjet
all ten of my Isspro EV's did this.Check connections at the amp box and grounds first. In my case it was bad gauges.
2001 f250 xlt reg cab 4x4,7.3 stock injectors,water/meth,ITP rr,walbro,5/8 pu,BD/MANN ccv,DP F5,OILGUARD,stock turbo,WW,ATS,1.0 exh.housing,high flow outlet,MBRP4",Billet 3-disk,built trans,Billsteins,11 ISSPRO PERFORMAX gauges,Scan gauge,08 rear cover,350 blocks,x-springs,AFE stg2/pg7,P265/75r16 NITTO Terragrapplers.
riverjet is offline
