Heatsoak? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 19 (permalink) Old 05-27-2010, 11:23 PM Thread Starter
F350 Balla
Send a message via AIM to 4eyedconekiller
Heatsoak?
Guys, I've got an e99 F350 that I recently put gauges in, and am noticing my trans temps creeping up while doing my in-town driving (which is 90% of how I use the truck), as well as my A/C wanting to fluctuate temp-wise when the truck is just driving around. I'm seeing trans temps at 190-200 in stop and go traffic, and have seen 210 before changing the fan clutch today.
Changed the Clutch, as it was a bit loose/weak. I rarely ever heard it kick on, but have noticed the new one doing it more often, so I'm sure its helping, but it didnt fix the problem. I actually noticed that the A/C kicked completely off today while I was idling at the shop.
I'm actually quite confused. The trans fluid was red when I got the truck, and I'm about to head out and check it again. I really don't need to be without my truck, as I work out of it.
Plans are:
-Blow out the stock dinky cooler, and see what comes out.
-Check and make sure fluid isnt changing colors on me.
-start saving for a 6.0 cooler, Sonnax, filter, and a bucket of mercon
-Put gauges on my A/C and see what my pressures look like.
Any other suggestions you guys would give me to get me by for now? I've seen the graphs aout engine life at temps, and understand the damage that these temps can cause. What would you guys do, in the essence of keeping the truck on the road as much as possible?
'99 F350
-DIY aFe Big Boost, MBRP 4",DI Tunes, ISSPROs, Sonnax/Tri, HD Headlights/5000k HIDs, Tinted tails, Painted XL Grille, Moulding/multiple emblem delete
-Tunes by Alpine, Boston Acoustics, Memphis Audo, and Audiobahn.
Look for drop, 22's, bedcover and wrapping up the dechrome
4eyedconekiller is offline
post #2 of 19 (permalink) Old 05-28-2010, 03:18 PM
<--Spy Vs. Spy
theSLEEPER's Avatar
Re: Heatsoak?
Anyone have experience with the Flex-a- lite fans?
228-365-0698
Sheep only have two speeds, 'grazing' and 'stampede'.
Regulated Returns are on SALE!!
theSLEEPER is offline
post #3 of 19 (permalink) Old 05-28-2010, 03:55 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Re: Heatsoak?
Originally Posted by 4eyedconekiller View Post
I'm seeing trans temps at 190-200 in stop and go traffic, and have seen 210 before changing the fan clutch today....
.....but it didnt fix the problem.
I'm sorry, but I don't see a problem. What are you trying to fix? Your temperatures are completely normal.
Mark Kovalsky is offline
post #4 of 19 (permalink) Old 05-28-2010, 04:07 PM
I Just Break Stuff
Re: Heatsoak?
As far as the a/c check your clutch and reshim as needed. Trans temp, figure about 100 deg over what it is outside, give or take.
06 f250 cc Lariat
4 inch Turbo Back
EGR Delete by FCDP
SCT w/Gearhead tunes
Lowered 3 Inches
ARPs
Barder stage 3
Warren Diesel 190/100s
Fluidampr
No Limit intake
Full billet Tranny
6.4 Banjos
AD II
CTS Monitor
GS Elite Gauges
Zex Nitrous
IPR Oil Cooler Relocation kit
irontx25 is offline
post #5 of 19 (permalink) Old 05-28-2010, 05:17 PM
<--Spy Vs. Spy
theSLEEPER's Avatar
Re: Heatsoak?
What are the normal temps Mark?? I may be the cause of all of his confusion. I could have sworn that 180-190 were where it should be unless you're pulling... What is the maximum acceptable temp?
228-365-0698
post #6 of 19 (permalink) Old 05-28-2010, 10:38 PM
Re: Heatsoak?
Maximum sustained temperature is 220F. Maximum short term, for no more than 1/2 hour, is 250F. Running 200F in stop and go driving is normal.
post #7 of 19 (permalink) Old 05-29-2010, 03:20 AM Thread Starter
F350 Balla
Re: Heatsoak?
Thanks for the help... Just hate that I freaked out as I did. The fan got a new clutch, so It couldnt have hurt. I do notice the new one kicking on more often than before.
Mark, I wish I had known you, or posted a thread before I did. It probably would have saved me some heartache and fundage. That fan clutch was an expensive booger! I'll probably keep my original one, just in case.
irontx25, are you talking about the A/C Compressor clutch, or the fan? Could you elaborate a bit for me?
-Michael
'99 F350
post #8 of 19 (permalink) Old 05-29-2010, 11:24 AM
Re: Heatsoak?
Fan clutches do wear out. It's likely that your 11 year old clutch was worn out and needed to be replaced.
post #9 of 19 (permalink) Old 05-29-2010, 02:03 PM
I Just Break Stuff
Re: Heatsoak?
A/C clutch. Its like any other clutch.....it wears. Mine would blow hot on full a/c. bought a new clutch and when i pulled the old one off i noticed it had shim washers on the hole the bolt goes through. I pulled 1 washer out ,slapped it back together.....cold a/c like it use to be.
06 f250 cc Lariat
4 inch Turbo Back
EGR Delete by FCDP
Lowered 3 Inches
ARPs
Barder stage 3
Fluidampr
No Limit intake
Full billet Tranny
6.4 Banjos
AD II
CTS Monitor
GS Elite Gauges
Zex Nitrous
irontx25 is offline
post #10 of 19 (permalink) Old 05-30-2010, 07:12 AM Thread Starter
F350 Balla
Re: Heatsoak?
ironx, that sounds like just the ticket! Will have to check into that ASAP
'99 F350
