trans tag noticed tonight.. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 31 (permalink) Old 05-26-2010, 01:42 AM Thread Starter
psd007.3's Avatar
soo i noticed a tag on the driver side of the trans house like right behind the gear selector..it was a white tag like siliconed on and it said remanufactured any idea how to tell what company manufactured this?? it looks like a ford part number on the tag but there is also 3 other numbers..im guessing if it was stock then it wouldnt have that tag on it??
KP
2000 powerstroke..skyjacker 6" suspension, tuff country ladder bars, s300 turbo,afe 4" exhaust, swamps 175/146cc injectors, afe stage II, adrenaline hpop,fuel system bowl delete, BTS valve body, dp tuner stock 60 tow,80 econ,140 aggr,sled pull, tci TC 1500 stall,studs,comp 910s, WOP plenums, Snow Performance Stage II...
psd007.3 is offline
post #2 of 31 (permalink) Old 05-26-2010, 01:44 AM
<---Best intake plenums
powertrip's Avatar
Re: trans tag noticed tonight..
Take a pic of it. I can look in my trans book and decode the numbers.
RDRCM #29
"New opinions are always suspected, and usually opposed,without any other reason but because they are not already common" John Locke
powertrip is offline
post #3 of 31 (permalink) Old 05-26-2010, 06:07 AM
canister's Avatar
Does it look like this? I asked a bunch of people what the #'s meant on mine and nobody could tell me.
1999.5 F250 w/ some stuff
canister is offline
post #4 of 31 (permalink) Old 05-26-2010, 06:19 AM
TARM's Avatar
That looks like a Ford inventory label so Ford remanf maybe?
TARM is offline
post #5 of 31 (permalink) Old 05-26-2010, 12:09 PM Thread Starter
psd007.3's Avatar
that pic is exactly what mine looks like exact same spot and everything...im guessing its not a stock trans then??
KP
psd007.3 is offline
post #6 of 31 (permalink) Old 05-26-2010, 12:24 PM Thread Starter
psd007.3's Avatar
its a ford remanufactured trans tag
KP
psd007.3 is offline
post #7 of 31 (permalink) Old 05-26-2010, 08:27 PM
Demon Dually
speeddemon31176's Avatar
Those are tags found on factory remanufactured transmissions from the dealer. That is all they are and nothing more.
speeddemon31176 is offline
post #8 of 31 (permalink) Old 05-26-2010, 08:35 PM
secondarychaos's Avatar
yup, I have one of those too. I know mine was reman'd by ford in 99.
Dan
96 Powerstroke: 6637, downpipe to dump exhaust, 140v IDM and a shift kit.
84 Honda Sabre V65 1100: pipes, jet kit and new tires. Faster than I think I'll ever need.
secondarychaos is offline
post #9 of 31 (permalink) Old 05-26-2010, 11:46 PM Thread Starter
psd007.3's Avatar
i wish i knew when mine was out in..will any of them numbers on the tag tell me that?? and is a ford reman trans any good?
KP
psd007.3 is offline
post #10 of 31 (permalink) Old 05-27-2010, 12:47 AM
roughneck0913's Avatar
shoot me a pm with the vin number i may still be able to pull it in oasis if it was done under warranty
roughneck0913 is offline
