zf5 clutch problems. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 05-14-2010, 02:11 AM Thread Starter
obs stroker's Avatar
well i was cruising along today, decided to get the truck out and for some reason i rest my foot on the clutch and the pedal went to the floor and the tranny started making this bearing sound the pedal was on the floor the whole time and fluid was leaking everywhere, what could this be im not any good when it comes to trannys, slave sylinder and throw out bearing??.....its been making the bearing sound at idle for a while now and this just made it louder, thanks jeff
FORD STOPPED MAKING TRUCKS ON 7/31/09!
1994 f-250 7.3 turbo diesel, intake, chip, 33's, 5 spd.
1994 f-150 good ol 300 six chipped and intake TB spacer, 5spd.
obs stroker is offline
post #2 of 7 (permalink) Old 05-14-2010, 02:30 AM
Boost Gets You Laid
Re: zf5 clutch problems.
Well you'll have to find the leak first! The only thing that holds clutch fluid (brake fluid) is the Master Cylinder (which is the little resevoir that is just to the passanger side of your brake booster) the braided steel line, or the slave cylinder. Replace the part that is leaking, refill and bleed just like you would brakes. The slave cylinder has a little bleeder valve on it. Hope this helps.
1997 F-350 7.3L
Hypermax Intercooler, DIY intake, RDS Stage 2s, Bob Rileys(CPR fuel system, HPOP Crossover, Coolant Filter) SouthBend Dual Disc clutch, TW custom tunes, Farmboys full 4", 17* HPOP,
1997 Jeep Cherokee
2004 Land Rover Discovery
1985 Mercedes 300 Turbo Diesel
2001 Sterling Silver Star
2005 Volvo VNT64T660
RCPro87 is offline
post #3 of 7 (permalink) Old 05-14-2010, 02:56 AM Thread Starter
i think it has a internal slave, and i think there one unit (slave and t/o) or is that just half ton, the fluid is coming out of the bell housing
post #4 of 7 (permalink) Old 05-14-2010, 04:05 PM
Boost Gets You Laid
Well the slave cylinder pushes the fork inside the bell housing so its possible that the seal on the inside end of the cylinder is bad.
1997 F-350 7.3L
1997 Jeep Cherokee
RCPro87 is offline
post #5 of 7 (permalink) Old 05-14-2010, 08:49 PM Thread Starter
ok, im tearing it down tonight ill post info
post #6 of 7 (permalink) Old 05-16-2010, 12:24 AM
Boost Gets You Laid
Got an update?
1997 F-350 7.3L
1997 Jeep Cherokee
RCPro87 is offline
post #7 of 7 (permalink) Old 05-16-2010, 01:23 AM Thread Starter
yup its the seal
