valve body install question - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 05-11-2010, 11:25 PM Thread Starter
neverkickn's Avatar
I went to install a bts valve body today and the filter screen under the origional valve body was not there. Been runnin for who knows how long without it. Will I screw it up by installing the new vb w/o the screen?
Thanks
01 f250 scsb Work Truck
neverkickn is offline
post #2 of 10 (permalink) Old 05-12-2010, 02:38 AM
Demon Dually
speeddemon31176's Avatar
Re: valve body install question
You need the screen. Go to a local trans shop and see if you can get one from them on the cheap.
speeddemon31176 is offline
post #3 of 10 (permalink) Old 05-12-2010, 02:42 AM
owner/president
dixieland-diesels's Avatar
Send a message via MSN to dixieland-diesels
Go to CarQuest and save some money.
03 lariat cc,4x4 7.3,DP-F5,36''MT,8"lift w/trac.bars,4"Silverline ss.exh,AFE II,Optimas,ATS housing,WW,Turbomaster,6.0 IC & tranny cooler,BTS,ISSPRO gauges,HPX,ITP RR,BRV+,Powerslots,WARN prem-hubs,coolant filter,ccv mod,08 mirrors,ARP's,mod.fuel & inj's.,Crower rods,AIH delete,AMSOIL fluids. ~waitn on the 38R~
dixieland-diesels is offline
post #4 of 10 (permalink) Old 05-12-2010, 02:59 AM
Demon Dually
Wait is he talking about the filter in the pan or the screen between the valvebody and case?
post #5 of 10 (permalink) Old 05-12-2010, 03:50 AM
tbolt's Avatar
When I installed my vb I'm almost sure the trans was orig and had no screen between vb & case. It still does not have one.
Glen
early99 f350 cc, lb, 2wd, drw, A pillar autometer guages, CTS monitor, AIS intake, 4" turbo back cat delete diamondeye exhaust, dptuner, pmt1, jw vb, Swamps ab inj, Adrenaline oil, Coolingmist, 180*T, Trucool cooler, spin on trans filter, Firestone air bags, 2" frt leveling kit, now chased by a 34' toyhauler
tbolt is offline
post #6 of 10 (permalink) Old 05-12-2010, 12:30 PM
owner/president
I tought he was referring to the filter as well.
post #7 of 10 (permalink) Old 05-12-2010, 12:52 PM Thread Starter
neverkickn's Avatar
Talking about the screen between the vb and trans body not the filter that draws fluid from the pan.
post #8 of 10 (permalink) Old 05-12-2010, 09:03 PM
Demon Dually
That's what I thought. Give Brian a call since you are in his neck of the woods. He could get you set right up.
post #9 of 10 (permalink) Old 05-22-2010, 12:47 AM Thread Starter
neverkickn's Avatar
I talked to Brian a couple days ago and he said not to worry about it. He mentioned that they see a lot of them with out the filter.
Thanks for the response guys
post #10 of 10 (permalink) Old 05-22-2010, 03:10 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
That screen is there to catch machining chips that are left over from the manufacturing process. You don't need to replace it.
Mark Kovalsky is offline
