BTS converter and Valvebody - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 05-09-2010, 12:48 AM Thread Starter
I am working on installing a BTS converter and Valvebody. Brain was a great help but doesn't work weekends The directions are pretty vague that came with the parts. The converter comes with a "torque converter regulator spring" that is supposed to be installed into the transmission pump. Has anyone pulled the tranny pump and can you just use threaded metric rod and a piece of flat bar pulling against the engine mounting surface to pull it? Thanks in advance
BIG-T is offline
post #2 of 13 (permalink) Old 05-09-2010, 01:00 AM
Member
vapstroke's Avatar
Re: BTS converter and Valvebody
I took two bolts that fit the pump and welded nuts on the end of them that allow me to thread on a slide hammer. I have two slide hammers and and evenly pull it. With one slide hammer you need to alternate back and forth so that you pull it evenly.
Swamps, ITP diesel, DP tuner, BTS, Stecher Performance Diesel, DieselSite
vapstroke is offline
post #3 of 13 (permalink) Old 05-09-2010, 02:55 PM
Pearson's Diesel
smokin dually's Avatar
I used a flat bar and 2 threaded rods like you are talking about to get mine out.
01 F350 cc dually 6sp conversion
00 F250 2.6 puller
early 99 F350 2wd daily driver
smokin dually is offline
post #4 of 13 (permalink) Old 05-09-2010, 10:21 PM Thread Starter
Step II
The threaded rod and angle iron worked great. For the people doing it under the truck like me remember to take out the tranny filter. That was a good heads up from a local tranny shop. I have the pump off now and cant figure out how to get the torque converter spring out. I wish I had a digital camera to help describe what I am talking about. The spring is held in the pump with thick threaded sleave of some kind. Anyone have any idea's? If not I am sure Brian could help in the morning.
BIG-T is offline
post #5 of 13 (permalink) Old 05-09-2010, 11:24 PM
Does this spring need to be put in place when using the tugger shift kit?
bigjake0524 is offline
post #6 of 13 (permalink) Old 05-10-2010, 07:14 PM
Called BTS this morning and they said not to even use the spring!
post #7 of 13 (permalink) Old 05-10-2010, 10:41 PM
TARM's Avatar
Well that sucks after pull'n the pump. Did they say why it was not needed when they sent it?
TARM is offline
post #8 of 13 (permalink) Old 05-10-2010, 10:55 PM
Just said sorry we try and open the boxes and take those out; must not have got that one removed!
post #9 of 13 (permalink) Old 05-11-2010, 12:00 AM
TARM's Avatar
Well live and learn. Its not like they do not have a awesome record and mistakes happen to even the best. Since then how far have you gotten?
TARM is offline
post #10 of 13 (permalink) Old 05-11-2010, 04:37 PM Thread Starter
I have been in touch with Brian. A pleasure to work with, I must say. And he did tell me to change it out. It is a bunch of work however. I am getting a friend over to help me move the tranny back under the truck and bolt it to the transfer case. I have no real complaints other than its tought to get questions answered on the weekends
On a side note I have been looking into injectors, tuners, and a supplier for a turbo and mounting kit. I have nothing but great experiences with Carson Stauffer Diesel, Rosewood Diesel, Jody at DP-tuner and Bill at PHP.
BIG-T is offline
