88 ZF 5 speed in a 97? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 05-05-2010, 02:44 AM Thread Starter
Clouse2411's Avatar
Send a message via AIM to Clouse2411 Send a message via Yahoo to Clouse2411
Well I screwed my tranny up that was in my truck and I have no idea when I'll be getting it back. My dad just bought a 88 7.3 idi with a 5 speed in it. It looks to be exactly like my tranny. I'm just wondering if I can swap it in?
97 F-350 RC LB.
Farmer's 400/400, Irate T-4 Mount And Regulated Return, Bullseye S475, ARP Main And Headstuds, Valair Double Disc, Intercooled, Short Throw Shifter, 4in Lift, Hood Stack, Black Interior, Autometer Gauges, Scan Gauge, Front And Rear Diff Covers, Dodge Tow Mirrors, 36x15.50x18 ATZs
Clouse2411 is offline
post #2 of 3 (permalink) Old 05-05-2010, 03:51 AM
95powersmoker's Avatar
Re: 88 ZF 5 speed in a 97?
I dont know much about manuals. so I am not going to be much help. However i do know there is a difference between the pre 95 and 95+ zf5 speeds. the pre95's are zf5-42 and the later ones are zf5-47. So there is a difference. I think the gearing itself is different. However my guess (and this is only a guess) is that it would be a direct swap. Just the gearing itself inside the tranny is different. I know for a fact there is a difference in the tranny's, not sure on the swap. Sorry if i was no help...
James
2000 F350 CCLB 4x4 auto, 250/200's from PIS, No Limit tunes, Isspro gauges, 4" exhaust and intake.
95powersmoker is offline
post #3 of 3 (permalink) Old 05-10-2010, 01:26 PM
F350 FF's Avatar
The bellhousings and are a direct bolt up/replacement. I am putting a zf-42 from a 93' IDI into my 95' PSD. The only real differences are that the -42 has a little higher first gear than the -47 and in stock configuration the -47 can handle a little higher torque input. But some good parts should take care of that. Hope that helps.
matt z
Have - 95' F350 PSD, 2WD supercab dually, E4OD, 4:10's, Tymar intake, 3" DP, Bully Dog 4" cat back, CPR fuel bowl delete / E-Fuel, Adrenaline Oil
Want - ZF5, Flatbed
F350 FF is offline
