Shifting without clutch? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 05-04-2010, 05:12 PM Thread Starter
tholt34's Avatar
Is it rough on the a zf-6 to upshift without the clutch like in bigger trucks? I have done it some and goes into gear great and doesn't grind. Just don't wanna mess anything up if its rougher on synchronizers or not.
Thanks Tim
2000 F-250 ext cab 4x4 6 spd. Glowshift gauges(egt, boost, and fuel pressure), PHP tuned, DIY intake. MBRP 5 inch straight exhaust with 6 inch tip
tholt34 is offline
post #2 of 14 (permalink) Old 05-04-2010, 05:16 PM
Powerstrokin'
cw96stroker's Avatar
Re: Shifting without clutch?
If it doesn't grind, and you aren't having to jam it in there i think it would be fine.. i can't really do it in my pickup (zf5) without grinding gears.. but with dads 2000 model sd i have no problems... its got over 300k on it and its still going so really dont think it would hurt much.
2001 Platinum with sum stuff done
1996 F250 I solded it
2008 lifted duramax dually
Originally Posted by NE-STROKE View Post
Be a real man. Stop. Pull over. Then throw a stick in his spokes if you are that upset.
cw96stroker is offline
post #3 of 14 (permalink) Old 05-04-2010, 05:38 PM
The Fireman
big_stroker's Avatar
I do it from time to time... As long as you have your rpms where they need to be when you do it you will be fine. You can even down shift like that if you know what you are doing.
big_stroker is offline
post #4 of 14 (permalink) Old 05-04-2010, 05:46 PM
Cummins?$?$?$?
greenmonster's Avatar
My five spd is pretty moodie, most of the time you can but you have to be within 200 rpms of its "sweet spot" or you have to clutch. So ill give it a little push into gear and if it doesnt go ill just push n the clutch. If you're peddle to the floor i wouldn even think about not using the clutch.
'95 F350, reg cab, Stage 1'S, Air Dog, TS 6Po, IDM mod., on 35's... thanx BDP
greenmonster is offline
post #5 of 14 (permalink) Old 05-04-2010, 05:56 PM
Haters Gonna Hate
Fordfreak4life's Avatar
don't grind'm to find'm and u will have no problems doing it, its all in the feel of the shifter
Fordfreak4life is offline
post #6 of 14 (permalink) Old 05-04-2010, 06:20 PM Thread Starter
tholt34's Avatar
Alright, thanks guys. I haven't quite got the downshifting right yet. Prolly won't worry about it. Just curious on the upshifting.
tholt34 is offline
post #7 of 14 (permalink) Old 05-04-2010, 06:23 PM
Haters Gonna Hate
downshifting is just as easy as upshifting just do it in reverse order in everyway, when u wana go down a gear let u rpm's drop off to about 1300 and touch the accelerator ever so lightly and slip it outa gear then apply slight steady pressure to the accelerator to make the rpms move up slowly, put just a touch of pressure on the shifter and it will slide into gear when the rpm's are right, if i can teach a 14 year old kid that couldn't drive a manual when we got in the pickup to do this in a half hour im sure u can figure it out, good luck
post #8 of 14 (permalink) Old 05-05-2010, 02:29 AM Thread Starter
tholt34's Avatar
Learning it aint a big deal. I just don't think about it when downshifting not to push the clutch in. hahhaha
tholt34 is offline
post #9 of 14 (permalink) Old 05-05-2010, 10:24 PM
Power Junky
Lubbockguy1979's Avatar
I drove a truck for 2yrs that had a bad slave cylinder by up and down shifting w/o the clutch... Now starting from a dead stop... That's exciting.
Randy
2006 f250 4x4 lariat cc swb 6.0psd torqueshift elec tcase soon to have isspro gauges air/fire/tranny/ fuel pretty much stock
Lubbockguy1979 is offline
post #10 of 14 (permalink) Old 05-05-2010, 11:09 PM
King Dingaling
TANK'S 250's Avatar
I do it on occasion in mine
TANK'S 250 is offline
