Wiring Diagrams needed..... - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 05-01-2010, 01:34 AM Thread Starter
I need a 97 Auto Transmission harness diagram.
Also need a 99 Super Duty ZF6 speed Harness Diagram.
I need to combine the harnesses to finish my ZF6speed Swap...Thanks Guys...
Sea97Stroker is offline
post #2 of 8 (permalink) Old 05-01-2010, 02:23 AM
OEM Moderator
Tom S's Avatar
Re: Wiring Diagrams needed.....
Steve I have the 97 book so I can help out there. I will try to remember to scan it on Monday when I get to work. If I forget cause I am bad about that remind me.
Tom S is offline
post #3 of 8 (permalink) Old 05-01-2010, 02:26 AM Thread Starter
Thanks a TON Tom, I appreciate that!!!!
post #4 of 8 (permalink) Old 05-01-2010, 07:14 AM
Demon Dually
speeddemon31176's Avatar
E4OD transmission electrical diagram at your disposal.
http://www.thedieselstop.com/faq/949...an/stjmain.htm
speeddemon31176 is offline
post #5 of 8 (permalink) Old 05-04-2010, 12:29 AM
OEM Moderator
Tom S's Avatar
Transmissions controls diagrams.
Tom S is offline
post #6 of 8 (permalink) Old 05-04-2010, 12:32 AM Thread Starter
Thanks Tom..
post #7 of 8 (permalink) Old 05-04-2010, 12:36 AM
OEM Moderator
Tom S's Avatar
2002 wiring book - Powerstroke Nation
SD wiring book is at that link.
Does that get you covered?
Tom
Tom S is offline
post #8 of 8 (permalink) Old 05-04-2010, 07:04 AM Thread Starter
That should, I will sipher it all out on my next days off. Thanks again!!
