transfer case - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 04-30-2010, 05:32 PM Thread Starter
Ticking time bomb
transfer case
will a transfer case of a 4r100 work on a e40d
I wonder what my sig and avatar will get changed to now!!
groomzybanshe is offline
post #2 of 4 (permalink) Old 04-30-2010, 08:54 PM
suprhlr's Avatar
Re: transfer case
yes it will physically bolt up
2000 f-450 suprhlr LA West conversion
04.5 fummins CR, twins by Engineered Diesel,
Hamilton cams, Exergy 40% injectors, 48RE suncoast/ Goerend converter PCS controller, airdog 2, smarty, 4.10 gears, 39k miles
suprhlr is offline
post #3 of 4 (permalink) Old 04-30-2010, 09:19 PM Thread Starter
Ticking time bomb
Re: transfer case
Will I hve to do anything special to make the 4x4 shifter work or the driveshafts
post #4 of 4 (permalink) Old 04-30-2010, 11:49 PM
Demon Dually
speeddemon31176's Avatar
Re: transfer case
If it is manual shift with an actual shift arm then nope you are fine. If it is an electronic shift good luck and have fun determining the wiring. Driveshafts for the superduty ypu pulled the t-case out of will be needed or conversion u-joints.
speeddemon31176 is offline
