e40d swap - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 04-27-2010, 12:56 AM Thread Starter
techteacher's Avatar
e40d swap
will a 1990 e40d fit a 1997 both diesel 4x4
techteacher is offline
post #2 of 3 (permalink) Old 04-27-2010, 12:58 AM
Re: e40d swap
should.
02 f250
countryboyrob is offline
post #3 of 3 (permalink) Old 04-28-2010, 05:25 AM
Demon Dually
speeddemon31176's Avatar
Re: e40d swap
It will bolt up with no problem. The issue you are going to run into is the connector for the solenoid pack. The older trans has a different plug configuration. You could swap the solenoid pack out with no problem though if yours is still good or just buy a new solenoid pack for it. They aren't very expensive.
speeddemon31176 is offline
