torque converter? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 04-24-2010, 06:30 PM Thread Starter
Loud pipes save lives
samoht517's Avatar
torque converter?
I think my tranny finally bit the dust. Driving home last night the torque converter slipped i think. Hit the throttle and the engine just reved then engaged after a couple tries and that was at 70mph. Then at a stop light it locked up and bogged the engine and stalled.
So im guessing my torque converter or maybe pump is toasted. Any thoughts before i start dumping money i dont have.
Its a stock E4OD that has kind of had a hard life. Hottest was 180* and highest launches were 15lbs consistent around 10-13lbs, power braking burnouts.
97 F-250 xl Regular Cab. Borg Warner TP-38, diesel site regulated return, adrenaline, purple trans
and some other parts to come
samoht517 is offline
post #2 of 4 (permalink) Old 04-24-2010, 06:43 PM
Captain Negativity!
PSDPlayer's Avatar
Send a message via AIM to PSDPlayer
Re: torque converter?
You can test converter stall by applying the brakes and giving it throttle. Look at where the truck starts to really try to move and thats your stall speed.
If the converter clutch was slipping you would get a code for that when it saw engine RPM and input shaft speed more than 50rpm apart.
If the stator sprag was blown up, the truck won't move.
So... Not the converter.
Email:
Phone:954-275-6801 Leave me a message. I can't always answer.
05 CC LB DRW Lariat 4x2 Dropped 3/6.
PSDPlayer is offline
post #3 of 4 (permalink) Old 04-25-2010, 05:08 AM
FordCowboy's Avatar
I'm not all that knowledgeable about trans stuff, but wouldn't the TC locking at a stop be related to a solenoid pack, or something electrical, in which case you should have gotten a code for that too.
Early 99 Powerstroke
Crew Cab Short Bed Lariat 4x4
SCT Livewire w/ various custom tunes
Adrenaline
AFE stage 2
Super 66 Turbo
4" straight pipe
Modded IDM
Automatic trans: PI Converter, tugger kit
Leveling Kit w/ 35's
FordCowboy is offline
post #4 of 4 (permalink) Old 04-25-2010, 01:31 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Usually the torque converter locking at a stop is caused by low fluid, a loose/missing internal filter, leaking internal seals, or a worn pump.
Mark Kovalsky is offline
