trans boggin/ stalling motor - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 04-24-2010, 03:19 PM Thread Starter
Crazy Talk
powerstrokenstang's Avatar
Send a message via AIM to powerstrokenstang
its bogging the motor when sittin still in gear, enough it hazes black. and when it shifts to 3rd its like you slam the brakes and just shuts it down. this is the e4od in my puller. thinking sprag in backwards. thoughts?
1996 F-250 ex-cab -D60- Motor,fire hoses-Nate,Tuning,Cam-Matt R,P-rods,dummy plugs-Wipe Out,Huffer-Engineered diesel,Carson,Gen3,Idm-Swamps,Rods,studs,fire rings-WOP,Clutch-Valair
455/400's in,S475 T-6 mounted
'84 f-350 2wd, 6.9l, 4spd, drw, flatbed. For Sale
powerstrokenstang is offline
post #2 of 4 (permalink) Old 04-25-2010, 02:48 AM
Demon Dually
speeddemon31176's Avatar
Re: trans boggin/ stalling motor
Sprag backwards is a good possibility. Lots of possibles really internally speaking.
speeddemon31176 is offline
post #3 of 4 (permalink) Old 04-25-2010, 04:49 AM
FordCowboy's Avatar
I've been wondering about this. Ever since my trans was put back together you can tell it bogs a bit when put into gear at idle, almost like the TC is locked but not that bad. It is a bog in the sense that you can hear the motor working more and RPM drop a bit, but it wants to pull through the brakes, is that similar to what yours is doing at idle?
Early 99 Powerstroke
Crew Cab Short Bed Lariat 4x4
SCT Livewire w/ various custom tunes
Adrenaline
AFE stage 2
Super 66 Turbo
4" straight pipe
Modded IDM
Automatic trans: PI Converter, tugger kit
Leveling Kit w/ 35's
FordCowboy is offline
post #4 of 4 (permalink) Old 04-25-2010, 02:11 PM Thread Starter
Crazy Talk
kinda, but the third gear thing makes it impossible to drive.
