Has this ever happened to your torque shift? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 04-24-2010, 05:02 AM Thread Starter
dwc032's Avatar
Its a 2004. When I try to take it out of park and into drive or reverse, it will not go. I have to move the shifter up and down 25-30 times before it will go into drive. I think it has to do with something in the steering column.
Have you guys ever had this problem? Its going to Ford tomorrow so we will see.
Never shall I fail my comrades. I will always keep myself mentally alert, physically strong and morally straight, and I will shoulder more than my share of the task, whatever it may be. One hundred percent and then some.
dwc032 is offline
post #2 of 5 (permalink) Old 04-24-2010, 06:52 AM
Captain Negativity!
PSDPlayer's Avatar
Send a message via AIM to PSDPlayer
Re: Has this ever happened to your torque shift?
Like you can't get it out of park? Or when you put it in reverse it doesn't move?
If it's the first one look at the brake pedal switch.
If it's the second one, look at the reverse planetary set.
Email:
Phone:954-275-6801 Leave me a message. I can't always answer.
05 CC LB DRW Lariat 4x2 Dropped 3/6.
PSDPlayer is offline
post #3 of 5 (permalink) Old 04-25-2010, 12:08 AM Thread Starter
dwc032's Avatar
Yes it sometimes has a hard time getting out of park.
dwc032 is offline
post #4 of 5 (permalink) Old 04-25-2010, 12:18 AM
Captain Negativity!
PSDPlayer's Avatar
Check the wiring to the switch on the brake pedal. Are the taillights working properly? If the brake switch is working. Next would be to check the brake shift interlock in the column...
Email:
post #5 of 5 (permalink) Old 04-25-2010, 05:52 AM Thread Starter
dwc032's Avatar
Ok, I will check that next! Thanks!
dwc032 is offline
