catastrophic failure.....twice - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 04-22-2010, 07:06 PM Thread Starter
chadow427's Avatar
hey guys, i need some help here. i've got a 95 f-350, reg cab long box 4x4. anyways, about a year ago the dual mass clutch was rattling, and i was busy with work so i had the local shadetree mechanic put a new single mass napa clutch in. drove the truck about 6 miles and the transfer case broke off the tranny, coming apart right in front of where it bolts up to the tranny. this happened at about 60 mph, and tranny, transfer case and drive shaft were destroyed. fast forward to now, i had just finished replacing all said broken parts, taking it for a drive down the road, this time made it about 2 miles down the road when the same freaking thing happened again!!! any idea what's going on??
06 F-350, King Ranch, cclb, bone stock
chadow427 is offline
post #2 of 10 (permalink) Old 04-22-2010, 07:18 PM
dadozer's Avatar
Re: catastrophic failure.....twice
Here is a dumb question for ya is the trans and transfer case mount in its the one that goes between the two?
2003 F350 7.3L CCLB 190k
29.5 lpm injectors, MBRP 4" turbo back exhaust, Tunes by Matt from Gearhead! WW, DIY intake w/ 6637 filter, leveling kit, Autometer guages
dadozer is offline
post #3 of 10 (permalink) Old 04-22-2010, 08:29 PM
Bigfoot is an OBS
cowboy_dan's Avatar
Huh? The only thing between the trans and the xfer case is a paper gasket. The xfer case hangs off the back of the trans on the OBS.
The xfer case input shaft slides into the trans output shaft, and there's a pin to clock the xfer case to the transmission. Then 5-6 bolts hold the two of them together.
Chadow:
That's impressive. Especially to have it happen twice.
My thoughts:
-Driveshaft length. Specifically make sure the front shaft isn't too long. Maybe you didn't get YOUR shaft back when the shadetree put it back together. If the shaft is too long, it will pound on the xfer case and try to twist it. This happens during suspension compression, such as when you hit a speedbump. I'd be more worried about this on an F250 that had a D60 put under it, but still something to consider.
-Make sure the xfer case has fluid and isn't already locked up. It might even be worth splitting the case of the next replacement just to do an inspection if you get it used (junkyard).
-Make sure the axle gears are in good shape. Strange things can happen if the gears get in a bind. I would hope you'd notice something like that, but with a catastrophic failure like that, sometimes other symptoms tend to get overlooked.
Go ARMY!
cowboy_dan is offline
post #4 of 10 (permalink) Old 04-22-2010, 08:48 PM
Maybe the shadetree f'ed something up with the clutch install???????????
2005 F-350 XL CC LB 4x4
Auto, SCT, Tunes from Eric, 03 Turbo, Exhaust, Coolant filter
2008 F-250 XLT CC SB 4x4
6.4 Auto, 6in Procomp lift, 37x12.50r20
Originally Posted by yogi7615 View Post
Unfortunately, there are too many animals wanting handouts and too many bleeders willing to give away other peoples money that it won't be easy to remove the stupid one.
willholl79 is offline
post #5 of 10 (permalink) Old 04-22-2010, 09:14 PM
dadozer's Avatar
IIRC there is a cross member that holds either the trans or the t-case im not sure.
dadozer is offline
post #6 of 10 (permalink) Old 04-22-2010, 09:38 PM
I think it holds the transmission and the t-case "hangs" out the back. IIRC
post #7 of 10 (permalink) Old 04-22-2010, 09:38 PM
Bigfoot is an OBS
cowboy_dan's Avatar
Cross member on the OBS bolts to the frame and trans only.
Go ARMY!
post #8 of 10 (permalink) Old 04-22-2010, 10:27 PM
dadozer's Avatar
I see so that's not the problem I told you guys it was s dumb question! On the second go around did you replace the drive line?
dadozer is offline
post #9 of 10 (permalink) Old 04-23-2010, 12:28 AM Thread Starter
chadow427's Avatar
thanks guys. there wasn't a front driveshaft on it currently, the old one had worn out and i hadn't put the new one back on yet. more and more i'm starting to wonder if there's something wrong with the rear end, but until everything fell apart it sounded and felt fine.
post #10 of 10 (permalink) Old 04-25-2010, 02:43 AM
Demon Dually
speeddemon31176's Avatar
You have a piece of gear orr something of that nature locking up the rear diff. The torque is then put on the driveshaft, t-case, and trans. Then kaboom. Pull the cover off the rear and see what broke.
speeddemon31176 is offline
