B&M Shifter - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 04-21-2010, 09:42 PM Thread Starter
B&M Shifter
I have just recently bought a 1995 F 350 powerstroke and the guy that had it be for me had installed a B&M floor shifter and its a piece of crap and doesnt work properly. Does anybody know how to put the shifter back into the steering column? I have the original column shifter and the cable is still sitting there. OR does anyone know of a good floor shifter for cheap?
llamaseh is offline
post #2 of 7 (permalink) Old 04-22-2010, 01:27 AM
Crazy Talk
powerstrokenstang's Avatar
Send a message via AIM to powerstrokenstang
Re: B&M Shifter
i got a floor shifter from broncograveyard. take the plastic off the top of the column its easy to put it back. iirc its a lil push pin or somethin.
1996 F-250 ex-cab -D60- Motor,fire hoses-Nate,Tuning,Cam-Matt R,P-rods,dummy plugs-Wipe Out,Huffer-Engineered diesel,Carson,Gen3,Idm-Swamps,Rods,studs,fire rings-WOP,Clutch-Valair
455/400's in,S475 T-6 mounted
'84 f-350 2wd, 6.9l, 4spd, drw, flatbed. For Sale
powerstrokenstang is offline
post #3 of 7 (permalink) Old 04-22-2010, 09:38 PM Thread Starter
Re: B&M Shifter
how do i connect the cable to the transmission? it is just laying down there
llamaseh is offline
post #4 of 7 (permalink) Old 04-24-2010, 03:10 PM
Crazy Talk
Re: B&M Shifter
it should have a snap on ball connection. if you need the lil lever that has to ball let me know.
post #5 of 7 (permalink) Old 04-25-2010, 03:58 AM Thread Starter
Re: B&M Shifter
snap on ball connection? what exactly is that? and how would i know if i needed it?
llamaseh is offline
post #6 of 7 (permalink) Old 04-25-2010, 07:35 PM
Demon Dually
speeddemon31176's Avatar
Re: B&M Shifter
The snap type ball connection is there. The B&M shifter utilizes it for their shifter assembly. If you look at the very end of the cable from the B&M shifter at the transmission you will see where it connects the the shift arm on the transmission. It connects to it via the ball stud. If you remove the B&M shifter and cable assembly, you simply snap the factory cable back onto the shift arm with a pair of pliers. Then reinstall the shifter on the column. You may have to do some rewiring if the PO relocated the overdrive switch to work with the floor shifter.
speeddemon31176 is offline
post #7 of 7 (permalink) Old 05-13-2010, 02:21 AM Thread Starter
Re: B&M Shifter
Hey thanks guys. got it all worked out and i just love her even more!!
llamaseh is offline
