chime if you got a SBC in OBS - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 04-21-2010, 01:49 AM Thread Starter
I just installed the 350hp/750 ft lb single disc and flywheel in my 95. Does anyone else have very slight harmonic vibration at idle? I assume its normal but want to confirm, I installed and torqued everthing according to instructions
03 F-350. EGR delete, ARP studs, BPD 7.3 fan clutch, coolant filter, cat delete, AT, 3.73s.
sg465 is offline
post #2 of 4 (permalink) Old 04-21-2010, 01:52 AM
Re: chime if you got a SBC in OBS
Rattles and growns at low rpm till you push in the clutch. Yep, The norm.
Rodknocker is offline
post #3 of 4 (permalink) Old 04-25-2010, 08:27 PM
very noisy until clutch is pressed in. Had another OBS drive past me as i was walking into the grocery store today with the trans growling. Just smile and wave knowing what it is
rsvrrider is offline
post #4 of 4 (permalink) Old 05-03-2010, 05:19 PM
Early bird gets the worm
95dieselsmoke's Avatar
yep. I have the Con OFE. prefectly normal to growl a bit. Sounds like a damn cement mixer down there doesnt it?
95 F250
Dana 60 swap
9" lift/40x13.5x20 ProComps
ZF5 swap/short throw/SouthBend CON OFE
Rosewood stage I's
TW live tuned
SD innercooler
AFE CAI
autometer pyro,boost
6" black miters
95dieselsmoke is offline
