Slave cyclinder/pushrod install ZF5 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 04-18-2010, 01:32 PM Thread Starter
I replaced my flywheel and clutch, got the tranny, driveshaft and starter back in. I just can't get the pushrod in on the slave cylinder to stay in long enough to install it between the mounting bracket and clutch fork..... GRRRRRGH!! Anybody have any suggestions?? '95 F350 7.3L psd ZF5 TIA!
jacmurr is offline
post #2 of 5 (permalink) Old 04-18-2010, 02:45 PM
Re: Slave cyclinder/pushrod install ZF5
I used a pullback ram with my porta-power to draw the clutch fork back.
'94 F250 supercab 4x4, original owner, 4.10LS, DIY elec fuel, Tymar air, Beans tunes on VA 4 position chip, Adrenaline HPOP, VDO boost/pyro/outside temp gauges, Ford digital AIC, DPPI downpipe, gutted EBPV, modded turbo ped, Con OFE, add-a-leafs front/rear, Monroe Reflex shocks, Milemarker 449SS hubs...coming soon: 6.0 IC...wish list: Stage 2's
nashvillebill is offline
post #3 of 5 (permalink) Old 04-18-2010, 02:50 PM
OverFuelingForYourPlesure
pontiacross's Avatar
i ususaly just push it up against the fork at an angle to get the rod back in the slave cylinder then just snap it on the transmission as I go up.
I guess you could break the bleeder loose to make it easier but then you would have to bleed it again.
Ross
2.6 modified street pulling truck "The Lone Stroke
-1996 f350, stock bottom end! swamps 400/400% injectors, swamps BFH turbo, swamps IDM, Swamps tunes, BTS oil, springs, studs, tubes, fuel system, water to air cooler, and much more...
-97 f350 4x4 CCLB tow rig
pontiacross is offline
post #4 of 5 (permalink) Old 04-18-2010, 03:37 PM
<---new toy
DPS0925's Avatar
What happened to the plastic holder?
DPS0925 is offline
post #5 of 5 (permalink) Old 04-19-2010, 06:11 PM Thread Starter
I got it! used ratchet strap. Thanks PSN for all help throughout the process! We have succeeded! New single mass flywheel and clutch kit and rebuilt ZF5! I'm lovin' it! The ol'e horse is back on the road!
jacmurr is offline
