What causes elevated tranny temps - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 04-14-2010, 03:00 AM Thread Starter
BRING DA AMBALAMPS
stroke of luck's Avatar
I'm running about 170 or so and I know that is a little on the high end. What are some things that can cause elevated trans temps?
2005 CC FX4...compounds and everything else that goes with em.
stroke of luck is offline
post #2 of 7 (permalink) Old 04-14-2010, 03:02 AM
King Dingaling
TANK'S 250's Avatar
Re: What causes elevated tranny temps
170?
I run 210-220 all day long on trips....mines a manual though.,
Normal is around 100* over outside temp...so if it's a sunny 70* day there...you're right were you should be.
TANK'S 250 is offline
post #3 of 7 (permalink) Old 04-14-2010, 03:14 AM
I Just Break Stuff
Sounds about right. I'm running anywhere from 160-185 during the day when it's 80 deg outside.
06 f250 cc Lariat
4 inch Turbo Back
EGR Delete by FCDP
SCT w/Gearhead tunes
Lowered 3 Inches
ARPs
Barder stage 3
Warren Diesel 190/100s
Fluidampr
No Limit intake
Full billet Tranny
6.4 Banjos
AD II
CTS Monitor
GS Elite Gauges
Zex Nitrous
IPR Oil Cooler Relocation kit
irontx25 is offline
post #4 of 7 (permalink) Old 04-14-2010, 04:10 AM Thread Starter
BRING DA AMBALAMPS
oh...well i guess i'm running ok then. thanks guys!
post #5 of 7 (permalink) Old 04-14-2010, 04:37 AM
FordCowboy's Avatar
Whats more important is that you know your truck. Although 170 may not be bad, Is it running warmer than it used to? Is it running warmer but the outside temp also has gone up about that much?
If everything else is the same but the trans temp has gone up a little bit, you may have something going on. Trans temps pretty much only go up from a few things. Friction of parts slipping or what not, or clogging in the cooler lines, or lack of fluid flow. In town driving runs hotter than highway obviously too, so if you made a switch like that you could expect it also.
If you always run 170 I wouldn't worry, but if this is a new rise in temp decide if you think it is an expected rise in temp or not. At that point decide if you think it is something that needs to be looked into more. From my experience, if you don't think the rise is expected, try to figure it out quick. Just this past week or so, I noticed my temps were up about 10-20 degrees more than normal. I was still only at about 150. Outside temps were up a bit, but I had a funny feeling. Well my TC had a broken bearing, I didn't drive it much after I had higher temps, but it still tore some stuff up. If I drove it more I may have been looking at a whole new trans.
Early 99 Powerstroke
Crew Cab Short Bed Lariat 4x4
SCT Livewire w/ various custom tunes
Adrenaline
AFE stage 2
Super 66 Turbo
4" straight pipe
Modded IDM
Automatic trans: PI Converter, tugger kit
Leveling Kit w/ 35's
FordCowboy is offline
post #6 of 7 (permalink) Old 04-14-2010, 04:49 AM Thread Starter
BRING DA AMBALAMPS
well, I've only had the tranny temp gauge on since the winter. it ran about 150-160 then and it was mostly in the 40's. it's starting to warm up into the 80's now so if it's supposed to be 80-100 over ambient then it sounds like it's normal. driving and shifting is the same as well.
post #7 of 7 (permalink) Old 04-14-2010, 04:56 AM
tbolt's Avatar
Don't fret about those temps. My truck with stock tires runs 160-180 in high80's and 200-210 towing my toyhauler in 110*+. I think Ford says 240 max. I haven't seen temps like that in this extreem temp here in Az towing in the mtns so I think you are fine. If you are worried about it put some tape over the guage. J/K
Glen
early99 f350 cc, lb, 2wd, drw, A pillar autometer guages, CTS monitor, AIS intake, 4" turbo back cat delete diamondeye exhaust, dptuner, pmt1, jw vb, Swamps ab inj, Adrenaline oil, Coolingmist, 180*T, Trucool cooler, spin on trans filter, Firestone air bags, 2" frt leveling kit, now chased by a 34' toyhauler
tbolt is offline
