NP 271 Input shaft instal???? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 03-28-2010, 06:44 PM Thread Starter
compresion ignition adict
STORMTROOPIN's Avatar
Swappin in a 24 spline input on my existing transfer case to work with the zf6 i swapped in my truck... anyone done this before... i have the parts and will be tryin this either tomorrow or some other day this week. Was wondering if there is anything i should do to help in doing this. Anything specific i need to do when instaling or removing the old shaft and gear?
04' F350 cummins conversion 12v/ZF6...
STORMTROOPIN is offline
post #2 of 5 (permalink) Old 03-29-2010, 03:50 PM
suprhlr's Avatar
Re: NP 271 Input shaft instal????
its pretty straight forward, you will need to remove the front driveshaft yoke and seal to get at a snap ring behind this, then just split the case in halves and remove everything in the front half to get at the input. just pay attention to how everything comes apart
2000 f-450 suprhlr LA West conversion
04.5 fummins CR, twins by Engineered Diesel,
Hamilton cams, Exergy 40% injectors, 48RE suncoast/ Goerend converter PCS controller, airdog 2, smarty, 4.10 gears, 39k miles
suprhlr is offline
post #3 of 5 (permalink) Old 03-29-2010, 04:18 PM
<--Spy Vs. Spy
theSLEEPER's Avatar
If you could maybe take some pictures... That would be awesome. I have a manual shift 6 speed T-case, but I need a manual shift AT T-case....
228-365-0698
Sheep only have two speeds, 'grazing' and 'stampede'.
Regulated Returns are on SALE!!
theSLEEPER is offline
post #4 of 5 (permalink) Old 03-30-2010, 08:36 PM Thread Starter
Ended up having the guy thats working on my ZF6 take a whack at it.... im so bussy tryin to finish up this cummins conversion i really dont have the time... hope it all works out though.
post #5 of 5 (permalink) Old 03-31-2010, 12:43 AM
<--Spy Vs. Spy
theSLEEPER's Avatar
Tell him to write a how-to!
228-365-0698
