Pulling 1997 7.3 E4OD codes and reading them - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 07-22-2019, 05:42 PM Thread Starter
Could someone please help with a definitive answer on where to pull the transmission codes from on an OBS 1997 7.3 E4OD 4x2 and whether it’s OBD-1, OBD-2, etc.? I’ve heard about 4 different locations and types and been through about a dozen threads and can’t get an answer. Also some recommendations on an actual quality code reader that’s reliable and worth the money. I don’t mind spending ~$350 as long as it’s not some overpriced junk. Perhaps multi function as well that could monitor engine/trans if possible? Thanks in advance
7.3ididgaf is offline
post #2 of 6 (permalink) Old 07-22-2019, 06:35 PM
alleged moderator
tjctransport's Avatar
Re: Pulling 1997 7.3 E4OD codes and reading them
it all depends on where the port is. if it is under the hood, it is not OBD-II if the port is under the dash it is OBD-II.
but i am pretty sure by 97 all diesel pickups were OBD-II
tom
tjctransport is offline
post #3 of 6 (permalink) Old 07-22-2019, 07:40 PM Thread Starter
Alright. So if somebody wanted to read the transmission codes for these trucks, which port would they pull them from?
post #4 of 6 (permalink) Old 07-22-2019, 10:14 PM
alleged moderator
if it is OBD II, it will not have an under hood port. if it is not OBD II, it will not have an in cab port
tom
post #5 of 6 (permalink) Old 07-22-2019, 11:28 PM Thread Starter
Okay I see what you’re saying now. Sorry I wasn’t understanding at first. Do you or does anybody else know of a reliable scan tool to figure out what’s wrong?
post #6 of 6 (permalink) Old 07-23-2019, 11:04 AM
alleged moderator
if it is OBD II torque pro or forscan are good tools. they are downloaded onto a tablet, laptop, or computer phone and then connect with a wireless device, or OBD to USB cable.
the download is around $5, and the bluetooth adapter or cable are $30 for a cable or $80 for the adapter
cable:
adapter:
even though the links say there is a problem, if you click on them they will take you to the proper page that describes each unit.
tom
