4r110 problems - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 03-24-2010, 02:20 AM Thread Starter
4r110 problems
I've been having some trouble with my tranmission. It is a 2001 F350 powerstroke automatic. The reverse is not engaging and it goes into drive on the neutral setting? Fluid looks good no leaks, no shavings, shifts smooth. In park it won't rev over 1000 rpms????? I'm clueless here.
2001 F350 SRW, Extended Cab Longbed
DP Tuned, 6" Superlift, 35 BFG MT's on Mickey Thompson 16x10's, 6" Turnout Stacks, DiPricol Optix x3, Warn Hubs, 6637 intake
edub32 is offline
post #2 of 11 (permalink) Old 03-24-2010, 06:27 PM
aklim's Avatar
Re: 4r110 problems
Is the adjustment off on the shift cable?
01 Excursion 7.3L Powerstroke. Gauges with AIH Delete, AIS, CCV Mod, 4' MBRP, BTS Trans, 6.0L Trans Cooler and Intercooler, DP-Tuner F5 chip, ITP In Tank Mod and Boost Annihilator, Diesel Innovation's Regulated Fuel kit, BTS Big Oil system, GTP38R Turbo with 1.15 A/R housing and BPD Stage II AC injectors. Bilstein Shocks with U front and A Rear.
aklim is offline
post #3 of 11 (permalink) Old 03-25-2010, 02:12 AM
tbolt's Avatar
Re: 4r110 problems
Thats what I was thinking. I would check that first.
Glen
early99 f350 cc, lb, 2wd, drw, A pillar autometer guages, CTS monitor, AIS intake, 4" turbo back cat delete diamondeye exhaust, dptuner, pmt1, jw vb, Swamps ab inj, Adrenaline oil, Coolingmist, 180*T, Trucool cooler, spin on trans filter, Firestone air bags, 2" frt leveling kit, now chased by a 34' toyhauler
tbolt is offline
post #4 of 11 (permalink) Old 03-25-2010, 09:39 PM
Keep er shinny side up!
Re: 4r110 problems
had a 99 in the shop the other day same complaints except the no rev over a grand and it was the shift cable WAY out of adjustment.
you ain't earnin' if you ain't turnin'
abbottfarms is offline
post #5 of 11 (permalink) Old 03-25-2010, 10:05 PM
Thomas7.3psd's Avatar
Re: 4r110 problems
how do you adjust it?..mine is out of wack to. thanks.
02 F250 cc sb Lariet 4x4.
BTS Transmission installed/tuned by TSD
Autometer Ultralite II Trans,Pyro,Boost.
MBRP 4'' Cool Duals turboback with 5'' tips.
DIY tractionbars with Procomp mounts.
6637/zoodad intake,Drilled/slotted Rotors.
Thomas7.3psd is offline
post #6 of 11 (permalink) Old 03-25-2010, 10:08 PM
aklim's Avatar
Re: 4r110 problems
4R100 Shift Linkage - Ford Truck Enthusiasts Forums
aklim is offline
post #7 of 11 (permalink) Old 03-28-2010, 06:51 PM
Re: 4r110 problems
If that ain't it(bet it ain't) you have clutches welded together.That requires a tranny rebuild.
2011 F-250 STOCK FOR THE MIN.
2005 GMC DURAMAX BUILT TO THE MAX I KNOW I KNOW.
nastynotchback1 is offline
post #8 of 11 (permalink) Old 11-16-2012, 03:07 AM Thread Starter
Re: 4r110 problems
tranny ended up being fried
edub32 is offline
post #9 of 11 (permalink) Old 11-16-2012, 12:07 PM
Re: 4r110 problems
If your keeping your truck and plan on mods...BTS, we can get you the best deal.
email:
Website:
OBSWIZ is offline
post #10 of 11 (permalink) Old 11-16-2012, 07:19 PM
Old Yeller, REBORN
kilapapipa's Avatar
Re: 4r110 problems
You just figured this out?
REBORN 20 Over on 3/2/11- Pics in gallery- 2000 F250, Auto, 38r, Full Force 238cc/100%, TE 17* hpop, DP F5,HI,60T,80E,120R,140A, Studs and 910's with DI PR's, JW VB in 2nd stock tranny, Walbro 392, Bellowed, In-Tank, Pre-Pump, boost fooler, and RR. Air Dog, SS cover, 6.0 TOC,4" straight piped and guages, 6637, coolant filter, 4" Lift on 33's.
kilapapipa is offline
