jim kelly's 1995 f150 2wd 4.9L e4od - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 03-03-2019, 09:49 PM Thread Starter
James Kelly's Avatar
hi guys. new to this site.
i have a 1995 f150 2wd 4.9 e4od and when i bought it a year ago it shuttered like mad at various speeds, so bad that it felt like the dashboard would fall off. i added instant shudder fix and shudder almost went away but the shudder is still there, but very very very much minimized. because i hear that instant shudder fix can be a temporary fix, just today i picked up a e4od from, i was told, a 1993 f150 351 engine. maybe i can check both trans for part numbers/etc?
my questions are... will it work in my truck? will i need to swap the solenoid pack from my 1995 trans into the 1993 trans? i'm also concerned because some say in my95 ford made some other wiring change to e4od. tcc?
i'm especially hoping Mark Kovalsky Former Ford Trans Engr. will chime in as i am too new to mssg him directly
and it seems i cant post pics either
jim kelly in DE
1995 f150 2wd 4.9L
James Kelly is offline
post #2 of 4 (permalink) Old 03-04-2019, 12:23 AM
Mark Kovalsky's Avatar
Re: jim kelly's 1995 f150 2wd 4.9L e4od
I believe that if it came from a 4x2 truck that it will bolt right in. You will need to swap in the 1995 solenoid body and probably the Transmission Range Sensor (TRS) on the side of the trans.
Mark
Mark Kovalsky is offline
post #3 of 4 (permalink) Old 03-04-2019, 03:51 PM Thread Starter
yes, the 1993 e4od is from a 2wd f150.
some pics here
914world.com/bbs2/index.php?act=ST&f=2&t=265392&st=200#entry2690601
post #4 of 4 (permalink) Old 03-04-2019, 10:13 PM Thread Starter
this guy has 3 videos and claims he put a 1993 e4od into his 1995 4wd truck successfully. swapping out the 2 items mark mentions above.
youtube.com/watch?v=LWUgt3kGHDY&t=147s
Similar Threads
90 F150 E4OD to 97 Powerstroke E4OD JMWRIGHT335 Transmission Related 3 05-11-2014 05:31 AM
1995 f150 2wd on mustang rims? jonnydiesel Gasoline Engine Forum 4 10-04-2013 10:24 AM
kelly TSRs Bradbilt 1994-1997 General Aftermarket 27 08-07-2012 01:23 AM
