Pulling my E4OD - PowerStrokeNation : Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By Mark Kovalsky
post #1 of 3 (permalink) Old 12-27-2018, 09:37 PM Thread Starter
KIB7.3's Avatar
Garage
Pulling my E4OD
I will be pulling my transmission this weekend and changing the front pump seal. I am losing about ˝ - 3/4 quart of ATF between fill-ups out of the TC inspection plate. Does anyone have any pointers on other things I should look at while it’s out? My dad says to change the rear main seal. Is there any special tools I need to do this? Any advice at all would be appreciated. Truck is a 96 F250, 4x4, with 300k Trans was built about 150k & 10 years ago (truck was my grandpas be fore he passed). I have no issues with the transmission, shifts great, and doesn’t get hot, ATF looks great, no burnt smell or discoloration. No complaints other than the puddle in the drive way.
XLT CCSB, 4x4, 3" Downpipe, 4" Exhaust (with CAT delete), 140V IDM Mod, TS6 Position Chip, K&N, Transmission built by State to state transmission in AZ
KIB7.3 is offline
post #2 of 3 (permalink) Old 12-28-2018, 02:02 AM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Re: Pulling my E4OD
Also replace the bushing behind the seal. Inspect the snout of the torque converter. If that surface isn't perfect the new seal is going to leak, too. There is an aftermarket seal available that is made from a material called Viton. It's MUCH better than the stock seal.
HilhavenFarm likes this.
Mark
Mark Kovalsky is offline
post #3 of 3 (permalink) Old 12-28-2018, 11:22 AM
matthewd11's Avatar
You must split the pump to change the converter hub bushing. It must be installed exactly the way it came out.
As mark stated check the coverter snout for any damage
matthewd11 is offline
