Would a cracked flexplate cause shudder? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 03-21-2010, 12:37 PM Thread Starter
Moved in
sagebel's Avatar
Truck shudders only under light accelleration emty or while the truck is loaded or towing. I found a couple cracks this morning while checking the TC mounting bolt torque. Cracks are where the flexplate bolts to the crank. I have had this vibration for over a year. Only happens at the base of hills and I can throttle out of it. When the truck is empty it is pretty random when loaded it's pretty consistant.
Also, what other damage could have been done driving it for over a year like this?
I was planning on starting my move Wednesday but that may now be delayed. Where do I get a new flexplate?
2011 F250 CC 4x4 Sterling Gray Metallic
2010 Cannondale Quick 4 (pedal powered commuter)
sagebel is offline
post #2 of 7 (permalink) Old 03-21-2010, 02:00 PM
All done now
Arisley's Avatar
Re: Would a cracked flexplate cause shudder?
Yep, it could cause it. If you don't change it, it might end up looking like this:
Arisley is offline
post #3 of 7 (permalink) Old 03-21-2010, 08:43 PM
Phiber Optik's Avatar
I have a similar issue but I have been leaning towards clutches slipping...
2008 F-350 CC SB Lariat, 4wd, 20x12, 35x14.5, 4" lift w/ Bags, 4" Exhaust, IC Pipe, Elbow, S&B Intake, EGR Delete, Gearhead Tunes, Hellwig Sways, Recon Ltng
2000 Corvette - JT Trim Vortech
2007 HusaberG FS650
2008 RZR - Z1 Turbo
Phiber Optik is offline
post #4 of 7 (permalink) Old 03-22-2010, 05:09 PM
My truck just lost the flexplate. I had shudder too. Fix it before you lose a tranny! The vibration isn't good for your tranny.
1997 F350 CCLB Dually XLT
1986 Bronco 6.9 Turbo XLT
Powertrain engineer by trade have worked for three OEM's.
86turbodsl is offline
post #5 of 7 (permalink) Old 03-22-2010, 05:50 PM
A Ghost these days...
farm boy's Avatar
I lost the flywheel in my pickup. Its in the shop getting fixed right not. I purchased a used flywheel off of ebay for $40. Mine had a loud grinding noise while in park or neutral that would fade away as the RPM's were brought up. It was frickin LOUD.
2002 F-250 4X4 Flatbed
~Cryo'd Forged Rods ~Comp 910's ~DI Push Rods ~ARP Studs ~IH Up-pipes ~GTP38R/1.15 ~238/80's ~Fuelab ~Built Auto ~Matt's Tunes ~Water Inj. ~Gooseneck Brand Flatbed
Rockin' Out with some help from: Alpine / Rockford Fosgate / Memphis / Infinity
farm boy is offline
post #6 of 7 (permalink) Old 03-22-2010, 05:58 PM
Coming For You
"THE DEMIZE"'s Avatar
Send a message via Yahoo to "THE DEMIZE"
Ill look I might have one and you pay shipping and you can have it.
97 F-350 cc lb 4x4
Swamps,Carson,Beans,Unlimited
"THE DEMIZE" is offline
post #7 of 7 (permalink) Old 03-22-2010, 11:23 PM Thread Starter
Moved in
sagebel's Avatar
Mine was probably only a couple days from looking like that. Mine seemed more jagged and was holding on by about 3/4". I also found that my transfer case was being held on by one loose bolt! I'll get a test drive in tomorrow since I need to take my parents to the airport(I'm taking the wife's van).
sagebel is offline
