08 f350 6.4 5r110w - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 08-14-2018, 07:08 PM Thread Starter
08 f350 6.4 5r110w
Hey, I am having some issues with transmission. I am getting a p0756 code and have high line pressure while in 2nd gear. Line pressure at idle in 2nd gear is 180psi, all other gears are pretty well bang on spec. I have already changed the b solenoid. What could cause line pressure to be high on only one clothe one clutch pack? Also dpf is deleted and am running Dirty Diesel custom tunes.
Blouin6.4 is offline
post #2 of 11 (permalink) Old 08-14-2018, 07:37 PM
matthewd11's Avatar
Is that in manual 2? What drivability issue does it have?
matthewd11 is offline
post #3 of 11 (permalink) Old 08-14-2018, 08:08 PM Thread Starter
Yeah that's in manual 2. Seems to jump in and out of second when shifting from first and has no over drive.
post #4 of 11 (permalink) Old 08-14-2018, 08:34 PM
matthewd11's Avatar
Does it engage gear in manual 2? It doesn’t look like o/d clutch is applying by pressure. If it won’t engage manual 2 you have a mechanical issue. Possible stuck clutch piston.
post #5 of 11 (permalink) Old 08-14-2018, 10:19 PM Thread Starter
Re: 08 f350 6.4 5r110w
It engages. But yeah I'm pretty sure there's something inside that is nfg.
post #6 of 11 (permalink) Old 08-14-2018, 10:52 PM Thread Starter
I was reading the atsg manual again trying to find something and it says a certainsensor failure may cause higher line pressure blah blah blah. So is it possiblenthe pressure switch for over drive clutch isn't opening and causing the pcm to send more amperage to the solenoid thus causing my over pressure?
post #7 of 11 (permalink) Old 08-15-2018, 02:48 PM
matthewd11's Avatar
Pressure switches were only used on very early 5r110s your late model does not utilize them.
post #8 of 11 (permalink) Old 08-15-2018, 03:55 PM Thread Starter
Right, now that you mention it I remember seeing upgrade plugs for that. Darn so much for that idea. And the only thingncontrolling line pressure for each clutch pack is the shift solenoid right? There is a main relief but ifnthat was sticking I would have near the same results in all gears correct? So if there was a short to power in the b solenoid wiring it could cause it to have higher than normal pressure but it would throw a code would it not?
post #9 of 11 (permalink) Old 08-15-2018, 03:56 PM Thread Starter
Sorry about the n's in place of the spaces still getting used to this tablet
post #10 of 11 (permalink) Old 08-15-2018, 06:06 PM
matthewd11's Avatar
Yes the shift solenoid controls the pressure to the clutch. If there is an issue with the wiring it should throw a code for the wiring. I believe that code is for a mechanically stuck solenoid, meaning it commanded the solenoid on but did not move.
Sent you a private message
