Transmission Cooler Kits - PowerStrokeNation : Ford Powerstroke Diesel Forum
 3Likes
  • 3 Post By Mark Kovalsky
post #1 of 4 (permalink) Old 06-27-2018, 08:30 PM Thread Starter
john_F350's Avatar
Looking at either a 6.0 cooler or a tru-cool option for my 95 F350...in central Texas my tranny is running at 180 - 215 degrees without towing...so looking to add a better cooler and probably a bigger pan. Does anyone make a complete kit for a 95' or am I stuck buying the hardware and hoses as needed after I get the kit.
john_F350 is offline
post #2 of 4 (permalink) Old 06-27-2018, 08:49 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Re: Transmission Cooler Kits
A bigger pan is a waste of money if you want to cool your trans. It's worth the money if you want it to make the underside of your truck pretty.
Mark
Mark Kovalsky is offline
post #3 of 4 (permalink) Old 07-05-2018, 04:36 PM Thread Starter
john_F350's Avatar
Put in a Tru-Cool max 40K on Tuesday...made an immediate impact...on a 100 deg Central Texas day it maxed out at 150 deg when it was running at 215 deg before...fairly easy install took me 2 hours and I go slow...mounted right where the old one was.
1995 F350 Crew Cab with 4" ProComp Lift / 315/75R16 Tires / 3" Downpipe w/ 4" Exhaust / DP-Tuner / Cold Air Intake / Tru-Cool Transmission Cooler / Guages
post #4 of 4 (permalink) Old 10-31-2018, 06:46 PM Thread Starter
john_F350's Avatar
Well the trans ran a lot cooler but ended up crapping out a few weeks back, had trouble upshifting...manual mode was fine...no codes...pulled black oil out of it....Took it to a trusted Transmission shop in the Austin Area (Eagle Transmission - Highly recommend)...The dropped the pan and it was filled with metal and fiber shavings. A total mess...It was supposedly rebuilt at 185K miles (had 216K when it failed) with "heavy duty" parts....It wasn't and they charged the guy $5K for the rebuild..
Eagle put a 3 clutch TC, all new steel valves, solenoid pac, etc...for only $3500 with a 3 year 36K mile warranty...runs and shifts good now....The tranny must have been going out already from the heat before I put the cooler in and finally just had enough...I least I know now it is done right and should last.
