ZF6 Carnage... - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 15 (permalink) Old 03-11-2010, 01:06 AM Thread Starter
compresion ignition adict
STORMTROOPIN's Avatar
ZF6 Carnage...
Bought this ZF6 trans from a member on here about 3 months ago while i was doing my cummins conversion... Found out when i get the trans home that it was full of rust. The guy had claimed that it had been in a garage for a year on the floor.. that i can belive. But the mistake by him of not keeping any oil in the trans let the iternals collect moisture and rust the inside of the trans. End result... when he sold the trans to me he had no knowlege of this. Thats fine, after i got the trans home and seen this i let him know rite away. We agreed that i try some seafoam and lucas. While the swap was in full swing i filled the trans with some fresh atf... seafoam and lucas and let it sit to break up some of the rust. When it came time to install the trans i drained the ATF and put the trans in. The first time we tried to fire the motor up with the trans attached no joy... the motor grunted like it was fighting against something then freed up all of asudden. When the motor finaly started there was a squealling and a knock coming from where the trans was. First we thought it might have been a bad clutch hyds or presure plate not letting the clutch dissengage but that was not the issue. The knocking stayed... the trans did not want to shift into gear while running. We finaly got in it in gear and took it down the drive way then back up... on the way back up the thing sounded like a roller coaster cart going up a hill...(click,click,click,click...) I had to be back to virginia because i was active duty navy so we left it at that.... I got home 3 weeks ago.. pulled the trans and took it to a good friend of mine that does transmissions and this is what he found.. The main bearings were sized up.... the main shaft actually ended up spining in its bearing sending shards of metal down into the gears. The badly pitted gears 1st, 2nd, reverse, 5th all got the brunt of the damage.. heres the pics..
Before we even knew what had happend.. my father contacted the guy who sold the trans to us. We asked if he might help cover the cost of parts and the guy prety much told my dad he was an idiot and didnt know what he was talking about... my dads been a diesel mechanic for 25+ years... civilian and 23 years in the army... What makes me mad is not the fact that he doesnt want to help make it rite its that he disrespected me and my dad after i paid $1200 for a transmission that he said had 36,000 miles on it....
04' F350 cummins conversion 12v/ZF6...
STORMTROOPIN is offline
post #2 of 15 (permalink) Old 03-11-2010, 01:31 AM
oilfield trucker
zpilgeram's Avatar
Re: ZF6 Carnage...
Wow that really sucks. Not to argue with you....but.... I am not completely sold that rust alone caused all that damage. The gears and internals appear to be pretty shiny and rust free. I would almost suspect there was mabey something else wrong with that tranny before you got it. I really can't imagine a transmission that was sitting in a garage would rust so bad that bearings would seized up. Just my .02, either way it sucks though. Sorry the guy had to hose you on it .
96cc,lb,4x4,zf5. DIY dual filter intake, intercooled,gauges,4''down pipe, DIY front bumper/grill guard,fuel tank mod, 238cc Rosewood Diesel hybrids,6pos chip from TDP,
stealth SRP1 HPOP,Garrett GT4294 with DIY mounting kit,valair 500hp kevlar/ceramic clutch,Dual SD pumps electric fuel system with regulated return,5'' DIY Straight pipe.
zpilgeram is offline
post #3 of 15 (permalink) Old 03-11-2010, 02:45 AM
Canadian Stroker
doubledoor's Avatar
Re: ZF6 Carnage...
Who was the psn member??
2002 XLT CC LB 6speed SRW
4"mbrp turbo back
S&B Intake
autometer NV boost,pyro,water temp and oil pressure
WW2,BRV
DP tunes - QI,60E,80E,40T,60T,100,120.
EBPV delete sensor.
blank pedestal and EBPV housing
ATS turbo housing
DI up-pipes.
2007 headlights,2008 taillights,2010 tailgate
17"Atx ledge with Dick Cepek Extreme Country
doubledoor is offline
post #4 of 15 (permalink) Old 03-11-2010, 02:58 AM Thread Starter
Re: ZF6 Carnage...
Idk about the rust issue..... it was prety bad at first than we let it soak and when we ran it it cleaned it up a bit... the fella that tore it down for me has been doin it for a while and he said the bearings were sized up in it... The guy that i bought it from said i must have been rhompin on it.. but thats more than far from the truth.. i took it down the drive way and back up..... And to break teeth on the gears like that would take some serious abuse or something seriously wrong.....
Doubledoor im not sure if i should post his name.... im not tryin to bag on him because that wont make it rite but if you want to know pm me and i will gladly share the info with you...
post #5 of 15 (permalink) Old 03-12-2010, 01:58 AM
Joshs4x4toyz's Avatar
Re: ZF6 Carnage...
That sucks man I hate dishonest and disrepectful pieces of trash. I agree trans must have been trashed before the rust with the extent of the damage, and if he acted like that to your dad i'd be willing to bet he's the kind of piece of $#!* that would sell junk. Sorry for your luck man, congrats on the swap though I hope it works out for ya soon
CC SB King Ranch BP'd 5.9 6spd +blah blah blah
Excursion BP'd 6.0 6spd +blah blah blah
CC LB Larryhat 6fo almost to the 1/2 million mile club
CC Larryhat F150
Dodge Pwagon
Lots O toys..
Joshs4x4toyz is offline
post #6 of 15 (permalink) Old 03-12-2010, 03:17 PM Thread Starter
Re: ZF6 Carnage...
Thanks man.. i gave the guy the benifit of the doubt... Ive got a line on another trans im hopeully gona go look at here soon... so well see.. the swap would have been done along time ago if the trans wasnt a pile of junk... its getting warm out and i really really want to drive the thing.
post #7 of 15 (permalink) Old 03-12-2010, 03:38 PM
cattle farmer
powerstroke742008's Avatar
Re: ZF6 Carnage...
thats too bad i hate when people rip you off...i bought a set of injectors and gen 3 pump off a member 4 months ago and have not heard from him since wont even answer e-mails...what has the world came too
Thomas,
97 f350 cclb-7.3
sticks,clutch,bars
05 f350 cclb-6.0
deleted, studed
powerstroke742008 is offline
post #8 of 15 (permalink) Old 03-13-2010, 12:55 AM Thread Starter
Re: ZF6 Carnage...
I hear ya... i just want to drive my truck so bad.... its been down since october.
post #9 of 15 (permalink) Old 03-13-2010, 01:24 AM
lubeowner's Avatar
Re: ZF6 Carnage...
I am looking for a zf-6 transmission and only need 3rd gear and reverse for a pulling truck built. I saw it was going in a 2004, so is it from a 6.0? Wanna deal?
Jeremy Johnson
Search "lubeowner" on youtube for many truck pulling videos.
dieseldr.net
We build Powerstroke pulling trucks.
lubeowner is offline
post #10 of 15 (permalink) Old 03-13-2010, 03:41 AM Thread Starter
Re: ZF6 Carnage...
PM sent, the trans is a hybrid.. the front case is from a 7.3.. the rest is 6.0
