5R110W fluid flush - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 03-15-2018, 09:45 PM Thread Starter
5R110W fluid flush
Just wanted to share a video I found that shows how to flush the 5R110W at any temp.
https://youtu.be/Ie4KdJCWDHE
drptpgt03 is offline
post #2 of 4 (permalink) Old 03-15-2018, 09:56 PM
Administrator
Zmann's Avatar
Re: 5R110W fluid flush
Hmm I was skeptical but
it looks legit the only cross contamination is the fluid running thru the cooler and lines
even a cold trans runs 10% of the fluid thru the cooler
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #3 of 4 (permalink) Old 03-16-2018, 01:41 AM Thread Starter
If you run enough fluid through, you'll eventually get all the old fluid out. I think having the tranny suck in 12 quarts will do the trick. Then top off the pan with 8-9 quarts. Then check fluid levels
post #4 of 4 (permalink) Old 03-16-2018, 01:50 AM
Administrator
Zmann's Avatar
I agree
i have seen this method discussed but the longer pan bolt trick is what separates this from the others I have seen
DTR's Donation page
RIP DTR Ron
Zmann is offline
