1997 f250 is stuck in drive - PowerStrokeNation : Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By tjctransport
post #1 of 5 (permalink) Old 03-11-2018, 05:48 AM Thread Starter
JohnnyJackMac's Avatar
Out and about this evening and tried to put it in park. Shifter lost all tension and became extremely loose. Trans is stuck in D and D2 and D1. Wonít shift up to neutral, reverse, or park. Got the truck home. Shut it off. Now I cannot get it started because itís stuck in drive. I got under the truck to manually put it in park and I can only shift in between the 3 drive gears. Canít manually put the selector switch up to park. Any thoughts? The shift cable does move when trying to shift in between the 3 drive gears. Any help will be greatly appreciated. Thx
JohnnyJackMac is offline
post #2 of 5 (permalink) Old 03-11-2018, 02:16 PM
don't play well w others
Dustybumpers's Avatar
Re: 1997 f250 is stuck in drive
Take a torx 50 and an extension, lie on your back under the steering column, on the floor
look up at the end of the shifter at the bottom of the tube under the column, you see 2 bolts. Tighten them up, and problem solved
Charlie
"A common mistake people make when trying to design something completely fool proof, is to underestimate the ingenuity of a complete fool."
Dustybumpers is online now
post #3 of 5 (permalink) Old 03-11-2018, 02:43 PM
alleged moderator
tjctransport's Avatar
yup. but make sure trans is on park first.
what i do is disconnect shift cable at trans and put trans in park. then inside cab and put shifter in park, and turn key off locking column. find the torx bolts that fell out of the column on the floor, and tighten them up. then get back under truck and put shift cable back on trans arm.
tom
tjctransport is offline
post #4 of 5 (permalink) Old 03-11-2018, 06:15 PM Thread Starter
UPDATE: Who ever owned the truck before me installed a shifter cable and Jerry rigged it. Under the dash, the shifter cable bracket was tie wrapped to a large wire loom and it broke. I put it in its metal bracket. Clipped it in and problem solved. Premature freak out guys. Sorry
post #5 of 5 (permalink) Old 03-11-2018, 07:59 PM
alleged moderator
nice. i just love hack repairs.
Dustybumpers likes this.
tom
