South Bend Help - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 03-09-2010, 07:29 PM Thread Starter
spb_2006's Avatar
South Bend Help
I recently replaced my clutch with a MU 1944 Con O 6 sp south bend clutch and immediately started having problems shifting into 2nd gear. Everytime I try to shift into 2nd it grinds unless I really granny shift but I dont have any problems with any other gears...Any help? Someone told me after I installed it that south bend clutches will tear up your tranny, anyone heard of this or know what its tearing up?
Sinister EGR delete, ARP Headstuds, replaced oem headgaskets, HD Bellowed up-pipes, 03 Turbo, SCT x3 with tunes from Gearhead...waiting impatiently for a bigger turbo and injectors...
spb_2006 is offline
post #2 of 5 (permalink) Old 03-09-2010, 07:33 PM
CamTom12's Avatar
Re: South Bend Help
I had an OFE and noticed a little of that, having to slow shifts down some. I think it has to do with the heavier mass your synchros are trying to slow down to get into the next gear.
2008 F250 CCSB FX4
DPF/DOC Delete, Spartan, Banks (previous owner installed crap) Intake and Cat-back, OUO Traction Bars, 40gal TFI Tank/Toolbox, EDE Studs, HG's, and EGR Delete w/ wastegate
1969 F250 RCLB Highboy
360/4-speed
CamTom12 is offline
post #3 of 5 (permalink) Old 03-09-2010, 10:12 PM
powerstroke710's Avatar
Re: South Bend Help
just did a auto to manual swap and used the same clutch, and havn't had any issues. i upgraded the clucth fork. everything went together smooth. have about 2,000 miles on it. shifts smoothly. good luck, sorry i can't help
2000 f-350 eclb lariet 7.3l, 8" lift, 18" rockstars, 37" nittos,projector headlights, euro tailights, recon led third brake light, recon clear cab lights, pocket flares, auto to 6 speed swap, south bend clutch,edge juice/attitude, superchips stacked, 5" exhaust to 6" stacks, diy intake.
powerstroke710 is offline
post #4 of 5 (permalink) Old 03-10-2010, 06:38 PM Thread Starter
spb_2006's Avatar
Re: South Bend Help
Every other gear works just fine other than 2nd but I cant shift normally cause it will grind in 2nd...
spb_2006 is offline
post #5 of 5 (permalink) Old 03-10-2010, 08:40 PM
Re: South Bend Help
you may ahve a problem with you snychroes, or 2nd gear. i'll bet its tranny related, not clutch.
