Trans actin up - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 32 (permalink) Old 03-07-2010, 05:23 AM Thread Starter
tholt34's Avatar
Trans actin up
I have noticed past couple days when i pull up to a red light, its like my trans won't go down into first and you can bump the throttle and you feel it drop in and shift fine. It doesn't slip, shifts great, fluid level is fine and fluid is good. Any ideas? its a 2000 f250 4x4 auto.
Thanks
2000 F-250 ext cab 4x4 6 spd. Glowshift gauges(egt, boost, and fuel pressure), PHP tuned, DIY intake. MBRP 5 inch straight exhaust with 6 inch tip
tholt34 is offline
post #2 of 32 (permalink) Old 03-09-2010, 07:52 PM Thread Starter
tholt34's Avatar
Re: Trans actin up
no one have any kinda idea. The o/d light will flash for a second and then quit and truck shifts out fine. My code scanner says no codes but i'm pretty its just not picking them up. I know I need to find out the code, but I just thought someone might have had this happen before and could give some advice of where to look.
tholt34 is offline
post #3 of 32 (permalink) Old 03-11-2010, 11:45 AM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Re: Trans actin up
Without the code I can't make a reasonable guess.
Mark Kovalsky is offline
post #4 of 32 (permalink) Old 03-11-2010, 03:52 PM Thread Starter
tholt34's Avatar
Re: Trans actin up
Alright, Well I tightened up the torx head bolts on the steering column that hold the shifter linkage and it tightened up my shifter and it hasn't acted up anymore. I was having problems with my truck not starting in park and would have to put it in nuetral, so i'm just wondering if it wasn't registering what gear it was suppose to be in good.
tholt34 is offline
post #5 of 32 (permalink) Old 03-11-2010, 03:58 PM
Jomax's Avatar
Re: Trans actin up
My dad had a DRW 1999 and when the O/D flashed it said the torque converter was goin out.
2000 F-350 4x4 DRW 200,000 miles DP tuner Stock, 40T, decel, 60T, 80T, 80eco, 120race, ported compressor housing, bellowed up-pipes, Terminator T-500, FPR Spring mod, AIH delete, autometer ford factory match boost, pyro, trans, HPX crossover tube, AFE Stage II CAI, 5in Straight pipe, JW valve body, Deep transmission Pan with magnet
Jomax is offline
post #6 of 32 (permalink) Old 03-15-2010, 06:41 PM Thread Starter
tholt34's Avatar
Re: Trans actin up
Mark,
Got codes scanned, its a p0720. What are some causes of that?
THanks tim
tholt34 is offline
post #7 of 32 (permalink) Old 03-16-2010, 01:11 AM
Re: Trans actin up
That's an output speed sensor code. It almost always is either the output sensor or the wiring to the sensor. It could be the target wheel, too, but that is VERY rare.
post #8 of 32 (permalink) Old 03-16-2010, 02:21 AM Thread Starter
tholt34's Avatar
Re: Trans actin up
Alright, thanks, i will check on it. Are those sensors expensive?
tholt34 is offline
post #9 of 32 (permalink) Old 03-17-2010, 12:49 AM
Re: Trans actin up
No, they are not expensive. Then again, my idea of expensive might be different than yours....
post #10 of 32 (permalink) Old 03-17-2010, 06:23 AM
FordCowboy's Avatar
Re: Trans actin up
Can you give more detail as to what the truck feels like or acts like when you say it doesn't feel like it goes down into first? When mine started to go, my torque converter wouldn't unlock at times when I came to a stop, so it was real sluggish and had that sluggish sound and kind of lurched a bit, then would catch itself and unlock.
Early 99 Powerstroke
Crew Cab Short Bed Lariat 4x4
SCT Livewire w/ various custom tunes
Adrenaline
AFE stage 2
Super 66 Turbo
4" straight pipe
Modded IDM
Automatic trans: PI Converter, tugger kit
Leveling Kit w/ 35's
FordCowboy is offline
  LinkBacks (?)
LinkBack to this Thread: https://www.powerstrokenation.com/forums/26-transmission-related/54872-trans-actin-up.html
Posted By For Type Date
2001 7.3 auto starts in 2nd - Pirate4x4.Com : 4x4 and Off-Road Forum This thread Pingback 11-24-2015 09:33 AM
