4r100 build - need suggestions - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 37 (permalink) Old 03-06-2010, 07:44 AM Thread Starter
edge186's Avatar
Im looking into building my 4r100 in my 01. Question is, what should i do to it.
here are the options that i've been considering.
Option 1: BTS converter and valve body. Approx $1300 + Labor Then eventually upgrade to a full BTS trans.
Option 2: Wait till trans blows up then buy a BTS trans. Approx $5000 + Labor, shipping, whatever else
Option 3: Go to local trans shop and have him install a billet converter and shift kit to prolong the life of the trans and then go with a BTS if it ever blows. $1500
I like option 1 the best but if i do that then im worried about something else breaking in the trans due to the higher torque multiplication ratio of the new TC. What do you think?
2001 F-250 PSD 4x4 Lariat CC SB Auto
Power Hungry Performance
Edge CTS Insight
ATS 4" Straight Pipe
ATS Ported Compressor Housing
AFE Stage II Intake
DI Stainless Up-Pipes
BTS Valve Body
6.0 Billet Converter
6.0 32 Row Trans Cooler
Foil Delete
AIH Delete
CCV Mod
Firestone Ride-Rite airbags
edge186 is offline
post #2 of 37 (permalink) Old 03-06-2010, 07:57 AM
TRX370r's Avatar
Re: 4r100 build - need suggestions
how many miles on your trans?
The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government.
Thomas Jefferson
Beans Diesel Performance
TRX370r is offline
post #3 of 37 (permalink) Old 03-06-2010, 02:48 PM
"mad cow" member
I wouldn't spend a penny on it until I crawled under it and checked the transmission build date.
2001 models with 4r100's built between 7-27-00 ~ 3-23-01 have a type of one way clutch (mechanical diode) which are prone to failure, the only cure is a full rebuild.
The build date is on the tag on the drivers side of the transmission.
3rd row down, you'll see BD then a number 0 = 2000, 1 = 2001, then a letter, A=Jan, B=Feb C= March etc, then two number's - 01-31 = the day.
01 F-250 CC 4R esof PMT AIS, pine tree air freshener,
some other stuff not worth mentioning .
Rustler is offline
post #4 of 37 (permalink) Old 03-06-2010, 04:28 PM Thread Starter
edge186's Avatar
I know its a factory reman trans but i don't know the build date. it got put in January 2007. estimated miles on it is 45,000
Edge CTS Insight
AFE Stage II Intake
BTS Valve Body
Foil Delete
AIH Delete
CCV Mod
edge186 is offline
post #5 of 37 (permalink) Old 03-06-2010, 04:34 PM
TRX370r's Avatar
I would check the build date but I would guess if its a factory reman you dont have the diode. In that case Id do a valve body,converter and pump mods. That should help it live alot longer and be better performing.
Thomas Jefferson
TRX370r is offline
post #6 of 37 (permalink) Old 03-06-2010, 05:56 PM
We can get you a BTS much less than $5K!
Cary
email:
Website:
OBSWIZ is offline
post #7 of 37 (permalink) Old 03-09-2010, 02:55 AM
5ninef250's Avatar
Cary
At a price less than going through BTS?
1997 F250 4X4, E4OD, 12v, SDX 5x14's & DV's, benched pump, 20*, 66/71/13SS, City Diesel 6OH I/C, D60 RSK, SD Springs
1997 F350 CC 4X4, Hypermax Stage 2's, H2E, BTS pumps, BTS trans, Banks I/C
5ninef250 is offline
post #8 of 37 (permalink) Old 03-09-2010, 03:17 AM
What kinda price can you get a BTS for? For the OP I would just get the BTS you will be happy trust me.
Anthony
2000 F-250 205k Few goodies
avancamp1 is offline
post #9 of 37 (permalink) Old 03-09-2010, 03:45 AM
linm up's Avatar
check with john wood auto, he builds some of the best 4r100 transmissions on the market. for under 4k. both of my trucks have been done by him, and they are awesome. the 97 is built for high hp, and he put the towmaster trans in my 2000. he also stands behind his work 100%. jd
linm up is offline
post #10 of 37 (permalink) Old 03-09-2010, 05:19 PM
aklim's Avatar
Option 2 with a twist
You can wait for it to blow or you can do a preemptive fix. With the preemptive fix, you are doing it at your timing instead of having it break in the middle of BFE.
I wouldn't put anything expensive behind the trans. I would get a BTS Valve Body simply because BTS will give you credit for the VB when you get a new trans.
I would go with BTS because after 2 yrs, he fixes it for free except you pay for shipping. Inside 2 yrs he pays for shipping. Nobody has said that anyone can do better than that. I chose BTS because while he and JW stand behind their product, he stands behind it longer and I know I will break my trans sooner or later. Probably after 3 yrs.
01 Excursion 7.3L Powerstroke. Gauges with AIH Delete, AIS, CCV Mod, 4' MBRP, BTS Trans, 6.0L Trans Cooler and Intercooler, DP-Tuner F5 chip, ITP In Tank Mod and Boost Annihilator, Diesel Innovation's Regulated Fuel kit, BTS Big Oil system, GTP38R Turbo with 1.15 A/R housing and BPD Stage II AC injectors. Bilstein Shocks with U front and A Rear.
aklim is offline
