Trans temp is really low - PowerStrokeNation : Ford Powerstroke Diesel Forum
 2Likes
post #1 of 12 (permalink) Old 01-15-2018, 05:14 PM Thread Starter
Hi all I have a 2005 f350 6.0 with 218000 and the 5r110 and the trans temps here the last few days have not been over 100 degrees f unless idling the stay more around 60 to 80 with out side temps being under 40. I was wondering if the thermostat might be stuck open or if this is normal. I use a bully dog ft to monitor but have custom tunes from quick trick I have been running the loony fuel tune. The truck is stock except for sinister egr delete and 4 inch exhaust.
Joes6.0 is offline
post #2 of 12 (permalink) Old 01-15-2018, 05:53 PM
matthewd11's Avatar
If that is truly the fluid temp then the thermostat is stuck open. Itís inside the pump . Trans needs to be removed , pump removed and split/disassembled to change it.
matthewd11 is offline
post #3 of 12 (permalink) Old 01-15-2018, 06:47 PM Thread Starter
Will it hurt the trans to run it this way
Joes6.0 is offline
post #4 of 12 (permalink) Old 01-15-2018, 06:48 PM Thread Starter
For a short time
Joes6.0 is offline
post #5 of 12 (permalink) Old 01-15-2018, 07:46 PM
Administrator
Zmann's Avatar
Re: Trans temp is really low
does it read the proper ambient temp before you operate it in the morning?
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #6 of 12 (permalink) Old 01-15-2018, 07:55 PM Thread Starter
It's with in 3 to five degrees of the coolant and oil so I am guessing so
Joes6.0 is offline
post #7 of 12 (permalink) Old 01-15-2018, 08:07 PM
Administrator
Zmann's Avatar
sounds like it is good
i have not read of a stuck open cooler flow valve before but your temps are low for sure IME @Mark Kovalsky ??
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #8 of 12 (permalink) Old 01-15-2018, 08:09 PM Thread Starter
My gauge on the dash reads in the middle or normal though when truck is at operating temp and the fluid on the stick is hot to the touch
Joes6.0 is offline
post #9 of 12 (permalink) Old 01-15-2018, 08:13 PM
Administrator
Zmann's Avatar
if it was me and I had no other means to verify what was going on and I verified the PID with another device
I would be tempted to throw a temp sender in it
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #10 of 12 (permalink) Old 01-15-2018, 08:23 PM Thread Starter
Yeah I am hoping mark will see this and chime in sounds like he's the guy to ask
Zmann likes this.
Joes6.0 is offline
