how to keep a trans from burning up in reverse? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 03-02-2010, 11:16 PM Thread Starter
bluedge8's Avatar
Mark, you had said it's easy to damage these trans (4r100 and 4eod) when backing stuff up, what causes the trans failure and how do you prevent it??? thanks in advance.
1997 f250 4x4 sclb, auto, 3.55's, 191k, diy intake w 6637, ccv mod, pyro, boost, trans gauges, 3" dp to 4" single exh. super chips for now. scangauge
Originally Posted by jdc753 View Post
Besides there is absolutely no way to idiot proof something, since they are always coming out with better idiots by the day
bluedge8 is offline
post #2 of 3 (permalink) Old 03-03-2010, 11:43 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Re: how to keep a trans from burning up in reverse?
Enough cooling will prevent it. You need the cooler in the radiator and a large external cooler. If you do a lot of backing with a large trailer you might consider a fan on the external cooler.
Mark Kovalsky is offline
post #3 of 3 (permalink) Old 03-04-2010, 12:34 AM Thread Starter
bluedge8's Avatar
thanks, sounds simple enough, I probably don't have to worry to much, but that question was bugging me.
bluedge8 is offline
