Transmission Performance Upgrades Help - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 40 (permalink) Old 03-02-2010, 09:42 PM Thread Starter
3YLSYKR's Avatar
I was wondering if anyone is using this kit or if you've done something similar for cheaper to improve the trans as they say this does in the link:
Bully Dog Shift Enhancer #151000
Also, what about one of these lock up kits, any one run one of these and arey they worth the buy?
TS Performance Torque Converter Lock-UP
8" Lift
38" Toyo MT's
DIY Traction Bars
Zoodad-AIH Delete-Foil Delete
Adjust. Wastegate
ISSIPRO Performax Gauges
4" TB Magnaflow Exhaust w/ 5" tip
AFE stage 2 PG 7 W/Pre-Filter
Superchips Prgmr 150HP/225TQ
Oil X-over Line
Smoked Lights w/LEDs & HIDs
DIY 3 stage Water/Meth
CCV
6.0 IC
Transgo Shift Kit
Derale Trans. Frame Rail Cooler
3YLSYKR is offline
post #2 of 40 (permalink) Old 03-03-2010, 05:26 PM
aklim's Avatar
Re: Transmission Performance Upgrades Help
How about just getting a valve Body. IIRC, BTS sells them for $225.
01 Excursion 7.3L Powerstroke. Gauges with AIH Delete, AIS, CCV Mod, 4' MBRP, BTS Trans, 6.0L Trans Cooler and Intercooler, DP-Tuner F5 chip, ITP In Tank Mod and Boost Annihilator, Diesel Innovation's Regulated Fuel kit, BTS Big Oil system, GTP38R Turbo with 1.15 A/R housing and BPD Stage II AC injectors. Bilstein Shocks with U front and A Rear.
aklim is offline
post #3 of 40 (permalink) Old 03-03-2010, 06:49 PM
The Fireman
big_stroker's Avatar
Get a valve body and a good custom chip that will tune for your tranny and ditch the super chips junk.
Half your problem is the super chips dont adjust worth a crap for your tranny shift points and a good custom tuned chip would.
Also you can make your own TC Lockup switch for about $10
big_stroker is offline
post #4 of 40 (permalink) Old 03-03-2010, 06:54 PM Thread Starter
3YLSYKR's Avatar
The inline pressure kit for 50.00 sounds a lot better than the valve body kit for 225.00
One day when I can afford a custom chip I will get one. I am trying to do as much as I can with lil money as possible that I don't have lol.
How do you make the lockup switch for $10.00?
8" Lift
38" Toyo MT's
DIY Traction Bars
Adjust. Wastegate
Oil X-over Line
CCV
6.0 IC
Transgo Shift Kit
3YLSYKR is offline
post #5 of 40 (permalink) Old 03-03-2010, 07:22 PM
The Fireman
I would save your money and just do it right the 1st time then to just try and piece it together cheap.
for the TC lockup switch get a DPDT switch and some wire and just find the wire on the harness on the drivers side finder that controls the TC lockup and run it into the cab through the switch and back out. I for get witch wire it is on the harness do some searching on here and you can find it.
Here is the diagram for the switch though.
post #6 of 40 (permalink) Old 03-03-2010, 07:31 PM
aklim's Avatar
Only if the question is "Which one do you pay less for NOW?". When I got mine, I had to only install it. I don't have to be sure that the measurements for the rest of the VB were within spec. Best of all, when my trans blew because of the diode, I got credit towards the trans. The VB is not a kit. They basically take a VB core, go thru the thing and make sure that everything is within spec. The BTS version has a plate where you can change the shift by making the hole larger at certain parts. In the kit you are talking about, you are responsible for everything. In my experience, things are cheaper for a reason and it usually doesn't involve someone being a nice guy. I bought Trick Flow heads instead of AFR heads because they were cheaper. Price sounded good too. 2 weeks after install, they sent me a set of guideplates because there was some issue they discovered. 2 yrs later, all the valves on the pass side were wobbling around and one had broken their spring and destroyed the piston. Was it cheaper?
DP-Tuner will load 1 tune onto your PCM for about $75 so you can try it if you want.
aklim is offline
post #7 of 40 (permalink) Old 03-03-2010, 07:33 PM
aklim's Avatar
Why not just get it programmed in the PCM to lower the lockup speed?
aklim is offline
post #8 of 40 (permalink) Old 03-03-2010, 08:33 PM
CGMKCM's Avatar
I had the Banks Trans command and my tranny took a dump at <50K miles. I would go with upgraded hardware (TC, Valve body etc.) over electronic (band aid) fixes any day.
Relying on electronics to fix your tranny will just raise the cost to fix it right when it goes.
[SIGPIC][/SIGPIC]
2001 F-550 4X4 Lariat
BTS Tranny
PHP Phoenix chip
H2E Turbo With WW II
Adrenalin
Banks Intercooler and exhaust
In tank and pre-pump mods
Numerous minor Mods
Other Diesels
08 GL 320 CDI
02 VW Golf TDI
3054 Kioti Tractor
Kubota ZD 323
CGMKCM is offline
post #9 of 40 (permalink) Old 03-03-2010, 09:50 PM
00Rich's Avatar
2008 F-250 FX4 cc,4x4
00Rich is offline
post #10 of 40 (permalink) Old 03-03-2010, 09:54 PM
owner/president
dixieland-diesels's Avatar
Send a message via MSN to dixieland-diesels
Yep thats the right price.
03 lariat cc,4x4 7.3,DP-F5,36''MT,8"lift w/trac.bars,4"Silverline ss.exh,AFE II,Optimas,ATS housing,WW,Turbomaster,6.0 IC & tranny cooler,BTS,ISSPRO gauges,HPX,ITP RR,BRV+,Powerslots,WARN prem-hubs,coolant filter,ccv mod,08 mirrors,ARP's,mod.fuel & inj's.,Crower rods,AIH delete,AMSOIL fluids. ~waitn on the 38R~
dixieland-diesels is offline
