John Woods Performance trans install - PowerStrokeNation : Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By Big Boy Toys
post #1 of 4 (permalink) Old 12-24-2017, 08:31 PM Thread Starter
Big Boy Toys's Avatar
Just recently blew my trans right after Thanksgiving. Now had an good readon to buy a John Woods Performance Trans ?. John is one hella guy called him to order and wasnt expecting to recieve til mid Jan of 2018. Recieved an email last week trans will be shipped and recieved this Tuesday. I plan on iii installing ats billet flexplate also. I will be taking pictures as i install the trans as i go.
Thanks to John woods i will be having a Merry Christmas
Whoknows likes this.
2000 f350 7.3l, 10" lift, turbonetics turbo, dp tuner, AFE stage 2 intake, 4" turbo back dual exhaust, guages, hutch and harpoon mod, upgraded fuel feed and return lines, john woods transmission, warn premium hubs, 2008+ full interior swap in process. 130k miles on odometer
Big Boy Toys is offline
post #2 of 4 (permalink) Old 12-27-2017, 01:09 AM
'Cody''s Avatar
Re: John Woods Performance trans install
Awsome. I have a JW valve body and it helped my trans shift a little better. It was definitely worth the money. I hope you like your trans.
Old Blue, 97' F350, CCLB, 7.3, Auto
Air: SD IC, 3" Plenums
Fuel: E- Fuel, 160/30 Injectors
Turbo: Irate T4, S366
Oil: T500, Melling LPOP
PCM: TW TS, IDM Mod
'Cody' is offline
post #3 of 4 (permalink) Old 12-28-2017, 05:11 AM Thread Starter
John woods performance trans showed up today. I cant wait to install. Just gotta change rear main seal and waiting for my ats billet flexplate to show up tomorrow. Along with SS Braided lines i had made at a local shop for the lines to my new mishimoto 37 row trans cooler. Which i had to shave off a 1/4" off each side of the tabs to fit.
post #4 of 4 (permalink) Old 12-28-2017, 05:17 AM Thread Starter
Here is 2 pucs of removing transfer case first which did make it easier later on to remove transmission. And 1 pic after trans and flex plate are removed. I used 19mm with a 10 inch and 6 inch 1/2" extension with an impact swivel to remove upper bolts on trans. Use a impact swivel i snapped my regular 1/2" swivel using my Milwaukee 1/2" impact.
