What lube to run in a ZF? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 02-27-2010, 07:14 PM Thread Starter
The Sound Of Madness
dieselboy01's Avatar
Whats a good lube to run in a zf tranny?
L99 SCSB 7.3 4x4 AEM intake, 5" straight pipe, 6pos Gearhead chip, Autometer gauges, Firestone bags, ATD Built tranny, Smoked lights, 15% tint, WW, Mr. Bobs boots & hoses, Leveled, Moto Metals
'02 F-250 RCLB 5.4 XL Plow truck
05 F-250 SCSB 6.0 XLT Plow truck
Remember kids, chrome wont get you home
dieselboy01 is offline
post #2 of 9 (permalink) Old 02-28-2010, 04:34 AM
OverFuelingForYourPlesure
pontiacross's Avatar
Re: What lube to run in a ZF?
I just run regular old ATF, I gues you could switch to synthetic ATF
Ross
2.6 modified street pulling truck "The Lone Stroke
-1996 f350, stock bottom end! swamps 400/400% injectors, swamps BFH turbo, swamps IDM, Swamps tunes, BTS oil, springs, studs, tubes, fuel system, water to air cooler, and much more...
-97 f350 4x4 CCLB tow rig
pontiacross is offline
post #3 of 9 (permalink) Old 02-28-2010, 03:56 PM
It calls for synthetic Mercon. I think I put in Royal Purple Synchromax.
'94 F250 supercab 4x4, original owner, 4.10LS, DIY elec fuel, Tymar air, Beans tunes on VA 4 position chip, Adrenaline HPOP, VDO boost/pyro/outside temp gauges, Ford digital AIC, DPPI downpipe, gutted EBPV, modded turbo ped, Con OFE, add-a-leafs front/rear, Monroe Reflex shocks, Milemarker 449SS hubs...coming soon: 6.0 IC...wish list: Stage 2's
nashvillebill is offline
post #4 of 9 (permalink) Old 02-28-2010, 04:20 PM
<--before leveler & block
stroker2's Avatar
I have the ZF6, not sure if that calls for different oil than the ZF5, but i put mobile 1 synthetic ATF in it and it shifts a little smoother. Had royal purple in it before that.
2000 7.3 F-250 4x4 CC/SB Lariat 6-speed, 2.5" leveler and F350 block, Swamps 200/30% injectors, Swamps tunes, GTP-38R, Valair: kevlar/ceramic clutch, 4inch exhaust, AFE stage 2,
DFA-regulated return, pre-pump mods, Isspro boost and pyro, scan gauge, ~420hp and 836tq
stroker2 is offline
post #5 of 9 (permalink) Old 03-07-2010, 04:13 PM
Red line MTF
Tan white tan 97 ECLB, D60 PMF, RSK SD springs front, airs bags rear, 4:10, intake, DP 4 exhaust DIY E-fuel, ZF-5 now
B&W turnover 5th wheel with Anderson hitch.
JCart is offline
post #6 of 9 (permalink) Old 03-08-2010, 03:50 AM
Canadian Stroker
doubledoor's Avatar
Stroker2 did you flush out your tranny cooler when you changed to the syn?
Or just drain and fill?
Thanks
2002 XLT CC LB 6speed SRW
4"mbrp turbo back
S&B Intake
autometer NV boost,pyro,water temp and oil pressure
WW2,BRV
DP tunes - QI,60E,80E,40T,60T,100,120.
EBPV delete sensor.
blank pedestal and EBPV housing
ATS turbo housing
DI up-pipes.
2007 headlights,2008 taillights,2010 tailgate
17"Atx ledge with Dick Cepek Extreme Country
doubledoor is offline
post #7 of 9 (permalink) Old 03-08-2010, 03:22 PM
stroker2's Avatar
Thanks
I just drained and filled. I was trying to find out what the process was to flushing the cooler but was unable to find it. Also, the guy that had it before me said he had royal purple in it. But i switched to mobile 1 and still noticed a difference.
The oil that came out of it was still pretty red looking also so it wasn't real dirty whien i switched oils.
stroker2 is offline
post #8 of 9 (permalink) Old 03-08-2010, 05:21 PM
Red Line FTW!
Tinscout is offline
post #9 of 9 (permalink) Old 03-08-2010, 05:34 PM
nchappy's Avatar
my ZF6 was very happy when i changed to mobil syn
nchappy is offline
